Question about GE Lands Phones
WHAT PHONE AND HEADSET?????>?
I ordered a Plantronics headset that was recommended to me. When it came I realized it is for plugging into a computer for VOIP. I cannot use it. I need a headset with a 2.5 mm plug to pkug into a phone.
i HAVE TYPED THIS 100 TIMES!!!
  • 21 Answers
Motorola v525 headset
Michael (Mobile Phone Engineer)
Universal Mobiles Coventry LTD
Posted on May 28, 2009
Plantronics M175 headset makes crackling noises when speaking with it on and is not loud and clear.
The 2.5mm jack on your phone, that the M175C plugs into, is more than likely causing you the problem. The phone manufacturers do not dedicate a lot of power to the 2.5mm jack, so sometimes people have a hard time hearing you or you hearing them. If you are using a cordless phone, you could use a Plantronics CS55H wireless headset. This headset is intended for only one phone line, not multiple lines. The CS55H's TR1 plugs directly into the wall jack instead of your cordless phone. This eliminates using the 2.5mm jack on the handset that is causing you problems. The headset come with a one year warranty.
Plantronics CS55H Wireless Headset
Good Luck from Headsets Direct!
Jun 22, 2011 | Plantronics M175 Headset
I have a CS70 NC./ no lifter. What is the set up procedure to use my headset without lifting my phone handset. With the base plugged into the headset port of the phone.
If the Plantronics CS70N wireless headset is plugged into the headset jack on your phone, you will need to push the headset button on the phone and then the call/control button on the wireless headset.
Good luck from Headsets Direct!
Jun 10, 2011 | Plantronics CS70 Wireless Headset
Had lost my Plantronics 220 for a year. am trying to pair with my Droid. can't remember how to do this. don't have any paperwork with me right now. what do I need to do? simple instuctions for a...
To find the User's Guide, check here: http://www.plantronics.com/us/support/docs/index.jsp?prodId=prod5920006
On Page 4 and 5 it details how to Pair the Bluetooth device to your phone.
For an Android 2.2 phone:
  1. Turn Bluetooth Headset on according to instructions in the Users Manual
  2. On phone, Go to Applications --> Settings--> Wireless and Network --> Bluetooth Settings
  3. From this menu you can turn Bluetooth on and once its on you can choose to Scan Devices
  4. Select your headset from the list.
  5. You will be prompted to enter a PIN or Code. By default it is 0000 (4-zeros)
  6. You devices should now be paired.
Hope this helps.
May 12, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My plantronics explorer 350 is paired correctly with my iphone 4, but I can't hear anything, it almost seems like it's muted, only it's not.
After doing some research for your phone, I have found that Apple does not list the Plantronics 350 as a recommended headset for the iphone 4. The recommended Plantronics headsets for the iphone 4 are Backbeat 903, Discovery 975, and the Explorer 395. Here is the link for the Explorer 350 User's Manual. It might just be that you have an old headset that is not compatible with a new phone.
Apr 25, 2011 | Plantronics Explorer 350 Wireless Headset
My plantronics Bluetooth will not go into pairing mode no matter what I do. I held down the call button and it does work. Are there any other alternatives?
When you hold down the call button do you get a red then blue flashing light? This is pairing mode. (also the only way to get this headset into pairing mode) Make sure the phone is close to the Bluetooth headset. For most phones pairing a headset is done by
  1. Settings/Tools > connections > Bluetooth > On (your phone manual will have all the specifics but this is usually the buttons)
  2. Turn your headset on (on/on switch) and wait till the indicator flashes red then blue.
  3. Set your phone to "discover" or "add a device" which steps are usually - setup > connect > Bluetooth.
  4. Once available headsets are available select your headset. If it asks for a code the generic code is 0000
  5. A successful pair is indicated by a blue light and also a confirmation on your phone.
Regards, Tony
Apr 20, 2011 | Plantronics Explorer 240 Bluetooth Headset
I can´t get the plantronics 220 headset to pair with my samsung corby
hello,
Step One:
Prepare Phone-
Turn on Bluetooth
For most phones, go to Settings/
Tools menu and select Bluetooth
or Connectivity and select "On."
(Or see the user guide for your
phone.)
Step Two:
Prepare Headset-
Pairing Mode
Begin with headset turned off. Turn
headset on (hold call control button
for 2 seconds until the light flashes
blue) and it will automatically go
into pairing mode, flashing red
and blue
Step Three:
Pairing-
Add Headset to Phone
For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device,
then Select "220Plantronics."
For passkey enter 0000. Headset
will flash blue when paired
successfully. It is now powered on
and ready to use hope it works
regards
shaun
Oct 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My Headset does´nt have dialtone, I was connecting to cisco phone 7941, 7970, 7911, and nothing, not work.
You can use a Plantronics S11 headset with a Cisco phone, however it is not the best compatible solution. To use an S11 with a Cisco phone, you have to make sure that you are plugging it into the handset receiver jack and not the headset jack. You will need to lift the handset receiver, set it off to the side, and then hang it up after each call. If you want a more compatible solution that you can plug into the actual headset jack and just press the headset button on the telephone to answer and hang up, then you would need one of the Plantronics "H-series headsets" with the Plantronics Cisco direct connect cable ( model 26716-01 ).
Plantronics 26716-01 cable
Plantronics H Series Headsets
Aug 12, 2010 | Plantronics S11 Headset
CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Use the commands on your phone to locate your headset.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
headset is now connected and ready to use.
Apr 15, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
I moved from a Blackberry world edition to a Blackberry Tour and now my plantronics explorer 210 bluetooth headset will not pair with the Tour. The Tour does not pick up the headset or my car speaker when...
I was having this exact problem and as soon as I did this it connected. I only had to do up to step 3. I have the same phone and the same headset.
How to Pair Your Headset if it Has Been Previously Paired
With Another Device
1 Turn the headset off.
Slide the power switch off, then wait until the indicator turns red
and then turns off.
2 Turn the headset on.
Slide the power switch on. After the headset is powered on, press
and hold the call control button until the indicator light continues to
flash red and blue.
3 Use the commands on your phone to locate your headset.
> Search > 2XXPlantronics. See your phone’s user guide for
more information.
4 When prompted for the passkey, enter 0000.
Pairing is successful when the indicator on your headset flashes
blue. Your headset is now connected and ready to use.
Apr 13, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Phone won't connect to the plantronics 222. When
I had that problem too. I finally realized that I had to press the enter key on my phone.
Apr 13, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Lands Phones Logo
71 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
