Question about Verona 34 in. CTG536S Gas Cooktop
Oven problems-electric plugs on oven face don't work
I have a corning 3+1 counterange. All 4 burners and the over work. However, the 2 electric plugs, along with the self-cleaning feature, does not work. I think I blew a fuse/breaker, but don't know where it is or what to do to fix it. Any ideas?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Why does my oven does not work but top burners are good
Not sure but newer stoves have 4 wires 2 110 and 1 ground and 1 neutral. Older stoves had 2 110 and only 1 ground. The oven sometimes used the ground a sa neutral for little motors, displays, etc. make sure that the third wire on your plug has a good ground and see if that helps
Jul 16, 2014 | GE Stove / Oven / RanCooktop Assembly -...
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
Hello I have a Miele Deluxe H818 oven With a Ceran Schott cooktop I would like to buy a used or new cooktop The size is 23 1/2'' by 20 3/4 the reason I would like to replace it is the top is marked and 2...
Hallo I have a Miele Deluxe H818 oven too.
I do not use my cooktop because I buy new with gas-metan.The original cooktop is only electrical.
Ivo
Nov 09, 2009 | Cooktops
One of my large burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Sep 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Large section of dual burner not working
Jul 07, 2009 | GE 30 in. Profile JP989 Electric Cooktop
I HAVE A CORNING COUNTERANGE. I THNK WE BOUGHT IT AROUND 1973. IT HAS BEEN A WONDERFUL APPLIANCE ALL THESE YEARS....BUT NOW THE OVEN THERMOSTAT DOES NOT WORK PROPERLY. THE OVEN LIGHT TURNS OFF BUT THE OVEN...
YOUR ADVISE DID NOT POSE A SOLUTION TO MY PROBLEM. I THINK YOU SHOULD REFUND THE TWENTY DOLLAR FEE YOU CHARGED ME FOR LESS THAN FIVE MINUTES OF "CHAT". NEITHER OF THE WEB PAGES HAD ANY HELPFUL INFO. WHAT A RACKET YOU HAVE GOING!
Nov 22, 2008 | Verona 34 in. CTG536S Gas Cooktop
Corning cooktop burner outage
The cooktop has to be examined for failure of the element or the switch. Some of the switches & some of the elements are still around. Have the elements checked for continunity. You will have to take it out of the counter and take the unit apart to do this.
Oct 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
Verona 34 in. CTG536S Gas Cooktop Logo
110 people viewed this question
Top Verona Cooktops Experts
Steve
Bosse Photos
Pierre Legault
Are you a Verona Cooktop Expert? Answer questions, earn points and help others
