Need to know what convergence chips are in Panasonic PT51HX41E
Anyone know the type of convergence chips are in a Panasonic PT51HX41E? Thank you very much
  • 8,617 Answers
Your model has two STK392-110 CONvergence Cs, you will also most likely need at least a few of the 2.2 ohm 2watt convergence resistors. I am posting a link to the actualrepair kit for your model which contains both Convergence ICs and all 6 of the convergence resistors and they send instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Posted on May 28, 2009
  • 3,459 Answers
Need to know what convergence chips are in Panason - 3_24_2012_6_00_06_am.jpg This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Posted on Mar 24, 2012
My panasonic pt51hx41e convergence will not line up
Clean the projection lenses with qtips and alcohol. Then try to use the convergence function. My blu was messed up on one side of the screen until I cleaned mine.
Mar 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Blue shadow in the picture
If you have gone into the customer menu and blue is skewed and will not adjust you have a convergence problem.
I will attach a photo--it will not look exactly like what you have but should confirm if it is your problem.
Most shops get 300 or more for this repair but actual total parts cost should be under 30 dollars if you buy the parts at the right place (I know a seller on Ebay).
Also I have START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR ON PT51HX41 THAT ALSO APPLY TO MOST PANASONIC SETS MADE FROM 2000-2006.
If you or someone you know can do it for you--you can save the set and a lot of money.
I can post the instructions here and if you think you can do it I can tell you the seller on Ebay to get the parts from--repair involves two things--being able to get at the chips this set uses and being able to unsolder and replace them.
I will try to post a photo of the two chips this set uses in a minute after I post this.
If you want the instructions let me know and I will post them for you.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 16, 2009 | Panasonic PT-51HX41 51" Rear Projection...
I have a panasonic rear projection tv model number PT51HX41E and the blue color is out of alignment I tried to fix it by adjusting the convergence manually but it wont let the blue line move far enough....
This is a fairly easy fix and I have detailed instructions on how to do it. You need to replace the two STK-392-110 convergence IC chips and any of the 2.2 ohm resistors around them that are discolored. The parts cost less than 20 dollars and you can get a pair of the chips on EBAY for less then 13 dollars plus shipping---Cost depends on if you are able to do it yourself or need to get someone to do it for you----Most shops here charge 300-400 for this kind of repair but I do it in home for many people here for 200-250 depending on model; 200 is much less than you can replace the set for and with new chips it should go 5 to 8 years until it needs them replaced again.
This is the slow time of the year for TV shops so you should be able to find someone in your area to do this IN YOUR HOME at a reasonable price.
I do this here for free--if this has been helpful please give me a vote here--if you need the instructions for replacing the chips let me know and if you have any questions:
etower.766@netzero.net
I have fixed hundreds of sets with Convergence problems
Aug 24, 2009 | Televison & Video
Color on Panasonic 2004 is off and appears to be warped
It sounds like a convergence problem; most of these sets use two convergence IC chips that both need to be replaced; usually this can be done right in your home.
Aug 16, 2009 | Hitachi 53SWX10B 53" Rear Projection...
Convergence problem
replace the stk-392-110 (x2) and any burnt resistors. cost 20$
Nov 19, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Convergence for HD channels only
Hello, please check the IC7102 (24LC64). This is eeprom that contains the convergence data. Please ask the Panasonic dealer if they can supply a replacement IC with the data for your HD. If you need more info please advice. Arpi
Jun 08, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT51HX41E
you need remote control that came with tv ,there is a service code menu for techicians only - setting convergence on these sets are not easy.you Must Know what you are doing other wise you can shut set down with bigger problems.Call a repair shop if your not sure.I have service codes but ,i will not tell someone these codes unless they do know How to set convergence.
Oct 23, 2006 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
342 people viewed this question
Top Televison & Video Experts
Electro Med Services...
