Question about Cell Phones
How to delete or reset life time call timer in moto yuva 270?
I want to set the timer to 0:0:0 how is it possible?
  • 544 Answers
it is dependds on the model of oyur unit.
may i hvae the model of your mobile.
thanks,
Posted on May 28, 2009
  • hernandezcur Oct 11, 2010
    ihave a moto ve440
Press back five times then turn it off. call any number then delete all then dip your battery in water and put it back in and your calls are gone. it works i did it
Posted on Jan 20, 2010
How to reset the bulb life to 0 on a sl4su it
hi,
Do the following for reset the lamp hour to zero.
Reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for 5 seconds.
OK
Sep 21, 2011 | Mitsubishi SL4SU ColorView Multimedia...
Tip
Motorola Secret Codes
<span>Motorola L6:<br />-----------------<br />hold * 65512890 for reset<br />hold * 5806 sw version<br />hold * 487989 NS lock menu<br />hold * 482896 CP<br />hold * 574243 NS<br />hold * 967678 SP<br />hold * 362628 IMSI<br />hold * 787090 Lock net level<br />hold * 787292 Lock net level<br /><br /><br /><br />Reset L7 security code without any cable<br />------------------------------------------------<br />press menu button enter 6 time 0 and then press ok<br /><br />*#06# IMEI<br />in permament test mode<br />(* hold 2 sec)<br />***113*1*[OK] net monitor<br />T205/T19x (ACER)<br />*#300# OK List the Software and Hardware version<br />*#301# OK Full Keypads functional Test<br />*#303# OK Set Default Language to English<br />*#304# OK Set OFF engineering mode<br />#304*19980722# OK Set ON engineering mode<br />*#305# OK Location: 1 OK<br />*#307# OK Engineering Test Mode<br />*#311# OK Phone code changed to default code<br />*#400# OK ADC, Cal val*<br />*#402# OK Adjust Display Intensity / Contrast<br />*#403# OK List the Manufacturing Informations<br />19980722 OK Master Unlock code for Phone and Sim Lock<br />*#302# OK Acoustic test*<br />7.1 Greeting<br />7.2 Main VlmGain<br />7.3 Input Cal<br />7.4 Output Cal<br />7.5 Side In Gain<br />7.6 Vox Gain<br />7.7 Min Mic Engy<br />7.8 More<br />(a) In Vlm Gain<br />(b) Aux Vlm Gain<br />(c) Silence Prd<br />(d) Supp Prd<br />(e) In Volume<br />(f) Out Volume<br />(g) Icon<br />(h) Image<br />(i) Animation<br />*3370# EFR ON (enhanced full rate)<br />#3370# ERF OFF<br />*#72837726# OK Confirm ?, Data saver<br />1234 OK Phone code default<br />*#0000# OK Setting saved, restore set phone do default language<br />*#0048# OK Fast change polish langpack<br />*#0007# OK Fast change russian langpack<br /><br /><br /><br />MOTOROLA 3xx<br />------------------------<br />*#06# and quick 'menu-key' and 048263* (Push the key quickly!)<br />and entering at field "OPTCODE" you must try several times.<br />If not working try with MOTO TEST CARD inserted.<br />Security code - 32*118*1*0*0<br />Model - 32*279*1*0*8<br />Flex ver - 32*383*1*0*0<br />Master Reset - 18*0<br />Master Clear - 18*1<br />Set band GSM 900 - 10*0*3<br />Set band DCS 1800 - 10*0*4<br />Set band PCS 1900 - 10*0*5<br />Set dual band GSM 900/1800 - 10*0*6<br />Read band - 10*1*0 =&gt; 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS<br />User code - 32*116*1*0*0 /coded:00310032003300340000 - 1234/<br />Read imei - 32*4*1*0*0 "OK" /coded:083a05092700247709 - 350907200427799/<br />47*4*1*0*9*081A32547698103254 =&gt; IMEI=123456789012345<br />it is possible to change IMEI<br /><br />ENJOY</span>
on Jul 11, 2011 | Cell Phones
Tip
MOTOROLA CODES
>>All Motorola Secret Code<<
Motorola L6:
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
*#06# IMEI
(* hold 2 sec)
T205/T19x (ACER)
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy
7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
#3370# ERF OFF
MOTOROLA 3xx
Master Reset - 18*0
Master Clear - 18*1
Read band - 10*1*0 => 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS
47*4*1*0*9*081A32547698103254 => IMEI=123456789012345
it is possible to change IMEI.........
on Feb 09, 2008 | Motorola Mobility L6 Cellular Phone
Replaced the projection lamp, it is still saying that it is ending reaching the end of its life, Is there a reset button?
  • 1
    The procedure may vary from Sony model to model. These procedures are for Sony Rear Projections only. For other models, please consult your manufacter's website. All rear projections have the option of reseting the lamp hours. This helps since you will know how many hours your last lamp ran for. Normal lamps should run between 5000 to 8000 hours.
    Try the following procedure:
    Please be cautious when entering service mode. Following the information below and you will have no problems.
  • 2
    Enter service mode by pressing Display, 5, vol +, Power On.
  • 3
    Proceed to the Option-E screen by pressing the 2 or 5 button
    Option-E 0 0
  • 4
    Change data to 1 using the 3 button on the remote
    Option-E 0 1
  • 5
    Press Mute Enter to write data.
  • Oct 29, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
    How can i reset my call timer in my nokia e63 mobile?
    if you reset the timer using the default code of 12345... it only delete time in call log list...
    to reset fully you have to install the newq sofware
    Oct 22, 2010 | Nokia E63 Cell Phone
    Moto yuva is my set. how can i tranfer my
    yes why not uu iss install a moto pc suite and contact...mess...anyy program any more sameer_mishra1@yahoo.com sent me mail
    Aug 25, 2009 | Cell Phones
    Pc suit for moto w230
    i m also stress about moto yuva w230 pc suit
    Jul 28, 2009 | Motorola Mobility W230 Phone US with...
    Gprs connection
    ask to mobile service provider for GPRS setting for Your phone model , after received setting than after you able GPRS service via your phone
    Jul 11, 2009 | Computers & Internet
    I need to find someplace to download the instructions, since mine didn't come with any
    I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
    I hope this helps.
    SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
    FEATURES:
    24 hour stopwatch
    Time-of-day and calendar
    Alarm clock
    BATTERY:
    Replace with LR41 battery
    TO SET TIME AND CALENDAR:
    From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
    Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
    Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
    Press and hold START/STOP SET button to advance digits rapidly.
    Press MODE button once to return to normal time display.
    From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
    TO SET ALARM:
    From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
    Press SPLIT/RESET button to cycle through minutes and hours.
    Press START/STOP SET button to change digits.
    Press MODE button to return to normal time display.
    From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
    TO ARM/DISARM ALARM SOUND:
    From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
    Alarm will sound when indicator shows in upper right corner.
    Release SPLIT/RESET button to return to normal time display.
    TO ARM/DISARM HOURLY CHIME SOUND:
    From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
    Chime will sound when dashes appear along top of display.
    STOPWATCH OPERATION - GENERAL:
    From normal time display, press MODE button once to reach stopwatch timer display.
    After use of any stopwatch feature, press MODE button once to return to normal time display.
    START-STOP (TIME-IN/TIME-OUT) TIMING:
    With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
    SPLIT TIMING:
    With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
    1-2 FAST FINISH:
    Press SPLIT/RESET button for STOP #1.
    Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
    Press SPLIT/RESET button. The stop time for #2 will now be shown.
    Press SPLIT/RESET button to reset the timer to 0.
    Apr 17, 2009 | Watches
    Cell Phones Logo
    486 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
