Question about Toshiba Satellite 1805-S253 Notebook
Problem with freezing/starting
It's an old 1805-s253 and its biggest problem is it won't boot most of the time.  The power light will turn on, but nothing inside is working and the hard drive light will not even come on.  It does this both connected to the ac and not.  Once in a great while it will seem to "catch", but then it will eventually lock up seemingly randomly, but especially if it is jostled whatsoever.  Just ordered a new hard drive hoping that is it, but any other ideas? anyone else have this problem?
  • mrbforshort Oct 22, 2007
    i can't believe it after all this time, but that sure seemed to do the trick, thanks!
  • joe_dallas09 Dec 27, 2007
    Yes - have the same problem - thought it was a loose connector so popped the plastic cover, lifted the keyboard and re-seated the only multi-pin connector I could see. This helped, but after about 6 shutdowns and powerups it did it again - so not sure what the issue really is - also reseated the hard drive - no effect.
    Scholar:
  • 181 Answers
Does the machine boot to bios? If so, it could be the harddrive. If it won't even boot to bios, try changing or re-seating the memory. These models are a bit buggy.
Thanks, good luck
Posted on Oct 22, 2007
I have a Toshiba satellite A200 - 1CJ, old of almost 1 year. It doesn't want to start AT ALL. After I plug it in, the battery's led looks red and the power led BLINKS blue. Have you any idea what happened?
It sounds as though your system is getting no power at all- try a second ac adapter. If that does not work, if in warranty, contact your technical support provider to get it serviced. If not, there is a good chance you will need a replacement motherboard- find a reputable technician and see about purchasing the replacement board.
Oct 09, 2010 | Toshiba Satellite 1805-S253 Notebook
Tip
Upgrade CD/DVD ROM to CD-RW/DVD ROM
I just replaced my original CD/DVD ROM with a Toshiba SD-R2512 CD-RW/DVD ROM in my 1805-S253 running Windows ME. I used "Roxio Easy CD Creator" for writing to CD's. Everything was "plug'n'play" except the bezel that came with the new drive had to be swapped out. Windows ME recognized the new drive immediately and I didn't have to load any new drivers. This upgrade will probably work on other 1800 or 1805 Satellite series machines.
on Apr 13, 2008 | Toshiba Satellite 1805-S253 Notebook
I have a Toshiba Satelite 1805-s253. When I turn it on, it attempts to start but then will immediately shut down with the power indicator flashing orange. I check the power supply and that is working ok.
power supply must b okay but the lead connecting laptop may have gone faulty, try changing it, if this is not the reason then some internal hardware problem
Sep 12, 2010 | Toshiba Satellite 1805-S253 Notebook
Toshiba 1805 will not start up - Operating system does not load, everything is blank!.
The RAM may need reseating or it maybe faulty.
If reseating the RAM module/s doesn't work and if you have two RAM modules, then try one at a time.
You could take the RAM to your friendly shop and get them tested or test them in another laptop.
Jun 01, 2009 | Toshiba Satellite 1805-S253 Notebook
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Mar 13, 2009 | Toshiba Satellite 1805-S253 Notebook
BIOS password
Not sure if you are up to this but if you remove the bios battery for a minute it will reset you may also be able to search for manual for laptop or you may have one
Jan 23, 2009 | Toshiba Satellite 1805-S253 Notebook
Laptop problem
oooh..blue screen too, I'll bet..you may need to boot from install cd, to recover, if you don't have a recovery disk..that is..
Feb 19, 2008 | Toshiba Satellite 1805-S253 Notebook
How to run setup
Hi
While holding the ESC key, turn the power on.
Do not release this key until a message appears.
Press F1 to enter the System Setup utility
Good Luck
Jan 13, 2008 | Toshiba Satellite 1805-S253 Notebook
Comes up a grey screen when I turn it on...
had same issue - on 1805-s253 - had to replace the inverter - there was a recall from Toshiba on that part for that series - you find sources for the part via a google of '1805-s253 inverter'
Dec 27, 2007 | Toshiba Satellite M55-S135 Notebook
Can't connect to internet using DSL
Open My computer, then My network places. Then open View network connections. Your connection should say "Local area connection". Right click it and make sure it's set to "Enabled". Then Right click it then select repair.
Nov 08, 2007 | Toshiba Satellite 1805-S253 Notebook
Toshiba Satellite 1805-S253 Notebook Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
