Question about Pioneer PRO-710HD 64" Rear Projection Television
Rgb computer to tv
I can watch the computer boot up but once xp starts it get wavey need help
  • 24 Answers
Check your owners manual to see which resolutions are supported.........
Posted on Jan 11, 2008
Rgb connection stopped working on laptop
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
I would like to connect my PC to TV Grundig GU32DVD to wacth a movie from internet on a tv screen What should i do
Once you're TV is connected to the PC. Go to the display settings and check if the computer detects multiple monitors. Identify the monitors and set your TV as the main monitor. If this a laptop there is also a switch that will let you toggle from the PC display to the TV.
Check the TV output some TV's needs the channel to be set to the output where the PC is connected.
Some says PC some may say VGA or RGB. (depends on the brand of your TV)
Once that is the output channel is set and the cable is connected then you should be able to use your TV as the monitor and watch that movie.
Hope this helps!
Jun 07, 2011 | Toshiba Satellite Pro L300 Notebook
I am trying to connect my Laptop to my tv Screen,so as to enable the family to watch alltogether. can you please advise. Thankyou
This is a very simple procedure to do. All you need to do is follow the instructions that i give to you below.
1. Get a signal cable(the cable that connects your monitor to your system unit).
2. After obtaining this cable get one end of the cable connected to the RGB PC port at the back of your TV(the port that has similar plugs to the port in which this cable fits into at the back of your CPU).
3. Connect the other end of this cable to the same type of port on your computer. It is usually by one of the sides of the Laptop.
4. Your computer may flicker or go blank at first but don't worry if the display doesn't come back once this cable is connected at both ends.
5. Change your Tv output to the RGB PC output frequency.
At this point, all the display and activities should be reflected on the TV screen and you can put any movies or programs for your family to watch together.
If you are having any problems setting this up, let me know and please let me know if you were able to set it up properly.
Hope it helped you?
Jan 21, 2011 | Compaq Presario 700 Series: 1170B01...
I have connected my pc to my vizio tv and watched it for two days now it says no rgb signal. the power will be turned off. How do I fix this so I can watch my pc on my tv
First check that your VGA cable is fully seated at both the TV and the PC. Make sure the computer is on and not hibernating or other power saving mode. (Try jiggling your mouse, running a finger on the touchpad (laptop) or typing a character on the keyboard.)
Try connecting the computer to another monitor. (Try a different cable.) Alternatively, connect the TV to a different PC. (This checks if the TV input or the graphics port in the computer is the problem.)
The other issue is which order were the TV and the computer turned back on. (Many TVs need to be on before the computer boots up.)
I hope this helps.
(I run my TV on the computer intermittently (for a dual monitor situation). The last time I did this, my computer did not detect the TV on reboot. In that case, I needed to reinstall my video graphics driver. However, that was simpler to diagnose since the other monitor was attached and working fine.)
Jan 16, 2011 | Televison & Video
Screen turns blue after Windows XP boot. It is
You cannot set your PC video resolution to 1920x1080 @60Hz?
Per user manual:
1. Set computer to a resolution supported by your HDTV (see Preset PC Resolutions). If your
computer supports it, we recommend 1920x1080 @60Hz.
2. Turn off the power to your HDTV and Computer.
3. Connect the VGA cable from your computer to the RGB PC jack on your HDTV.
4. Connect the 1/8-inch audio cable from your computer to the RGB PC Audio jack on your HDTV.
This step is optional and only needed to transmit audio from the computer through the TV.
5. Turn on the power to your HDTV and computer.
6. Select RGB using the INPUT button on the remote control or side of your HDTV.
Note: Refer to your PC computer user manual for more information about the video output requirements.
Sep 07, 2010 | Vizio VM230XVT 23 in. TV
I assume you know how to get into the BIOS screen. If not watch carefully while the system boots. It will tell you which key to press. It could be del(delete) or F2 or F8. Once you know that, shut down the system. wait about 30 seconds. Turn the computer on. Immediately start pressing the key to get into BIOS. Once in, change the sequence of boot device from Hard disk to CD drive. save and exit. open the cd tray put your XP CD in it. switch off the system. Write down the CD key on a sheet of paper. It is a 20 character long code. You will find it on the back of the PC. switch on the computer. Your computer will boot from the CD and give you the installation screen. Select fresh installation. Let it complete. It may ask a few questions like your name, computer name domain etc. You may name it as you wish.
Jan 31, 2010 | Microsoft Windows XP Professional With...
Pc is in a startup loop - boots up to windows icon - begins to load windows then bangs out to ''RGB No Signal'' before going into startup routine again. Will not even start in safe mode or any of the other...
I would boot the Windows XP CDROM and select repair and continue to the recovery console. logon with administrators password (usually blank) and it drops you at a dos prompt where you type chkdsk c: /p and press enter. If chkdsk runs, allow it to complete then reboot.
Jan 20, 2010 | Computers & Internet
Pioneer PRO-710HD 64" Rear Projection Television Logo
294 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
