Question about Microwave Ovens
My Dometic over the range micro wave was working perfectly until the lights went out under it, I removed the bulbs and one was shot but the other looked good, so I got out my tester to see if it was getting electric current to it, I accidently touched the probes togeather and created a short which kicked off the breaker. Resetting the breaker, everything on the oven works now, the display, the clock, it even counts down, but the micro wave, nor the exhaust fan will come on. I replaced the fuse, and checked it also, it is good, but the oven and fan still will not come on.
  • johnbroughma May 28, 2009
    It is a Dometic over the range Model # DOTR12CBIV It is installed in a RV If control board is shot, would the touch pad still work and would it count down?
    Top Expert:
  • Microwave Ovens Master
  • 76,691 Answers
It is very likely you burned out the control board, I suggest this should be repalced as a solution to this problem. I have no way of looking up parts for this because u din't provide make or model. U can try a site alled the "repairclinic" for parts
Posted on May 28, 2009
  • yadayada
    yadayada May 28, 2009
    If any of the functions of the board don't work then the board is defective, the fact that some parts work means the board is getting power, so it is really the only thing that can cause this, it is very seldom that all functions of any appliance control panel fail. I have no sources for motor parts, u will need to contact an RV retailer for parts sources.
Micro wave oven light works as a work light but when you hit the button for the night light to come on it doesn't come on hit the button again and it's off
The problem is on the control panel, which can be repaired economically.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jan 17, 2013 | Microwave Ovens
Range lights on a over the range GE mirco wave won't work. The touch pad works and says the lights are on but no lights
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
Or you can buy and install a new control circuit board (smart board) from the Pros here, our favorite supplier.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
Oct 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
WHERE DOES THE BULB GO?
Ccess to the bulb is under the outer cover of the micro wave. Unplug the unit for a few hours before removing the covers. Once the cover is off you will see where the bulb is and you can replace it. Replace and secure all the covers before plugging the device in again.
Jan 30, 2011 | Microwave Ovens
Micro wave range light blew out when turned on. Removed old bulb and it had some white plastic melted on it. Replaced the bulb, and the light doesn't work.
Your going to need to disassemble the light fixture to perform electrical work. Its possible in the process that you may have accidently blown something else. If so, be prepared to peform
units soldered connections on the main projection board warm up as the system warms up. Thus, the loose capacitors, resisters, and diodes are causing the CHANGE when the system warms up. When metal contracts, it expands thus losing the connection needed for a solid connection. This process is normal after the units have reached their service life. Keep in mind that you can repair this but at the expense of time if you have never performed this type of work.
Jan 26, 2011 | Whirlpool MH7140XF Microwave Oven
The surface lights burned out so I was going to replace these. I took the lens cover off and when to unscrew the bulbs when I heard a "pop" no there isn't any power to the micro wave. What do I do now?
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You should of course replace the fuse, but always work with the oven unplugged.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Oct 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave works but light burn out how doI change
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs (and 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Jan 29, 2010 | Daewoo KOR-1B4H Microwave Oven
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
I like my micro wave. However it is working without light. You know the light turn on when it is working. So, I worried about it has some possibilty of wrong.
You might find an access panel inside the oven. If so, remove it and change the bulb. Otherwise, you will have to remove the cover to get to the lamp.
Thanks for your interest in FixYa.com
Dec 11, 2009 | Microwave Ovens
Broken light bulb
Go to an appliance parts store to get the bulb.
Good Luck and Please rate fixya!
Feb 23, 2009 | Jenn-Air JMV8208A Microwave Oven
Light under sharp built in micro wave oven will not shut off
Sorry, but your subject line was too long and it got cut off.
I'm assuming your cooktop light blew and even though you installed a new one, it still won't come on?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Jan 12, 2009 | Sharp R-1501 Microwave Oven
Microwave Ovens Logo
288 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
