Question about Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
Acer 4520 cd/dvd driver problem
My cd/dvd drive is unable to detect any cd/dvd.there is no icon for cd/dvd drives in 'my computer' .device manager also doesnot show the cd/dvd drives.wat should i do? I'm also having the same exact problem. I'm using an ACER 4520 Aspire. Running both Ubuntu/linux and windows vista (rarely). My laptop stopped reading or detecting my DVD writter a few days ago. Neither OS nor BIOS are detecting my DVD I've tried another internal DVD combo from an old Toshiba laptop of mine that works like a charm on Toshiba. But never worked on My Aspire. I guess the problem is with the motherboard, and it seems ACER isn't a leading company as I thought it was, at least in my perspective. I'm intending to buy and external DVD... what to do!!! Just liked to participate, coz I'm really pissed off.
  • 674 Answers
Try to use another DVD. you told you tried you old DVD from your toshiba. maybe is not compatible.. try in another.. then use your DVD in another laptop if the same from problem.check your board and DVD connection...if this under warranty bring to warranty..
if in Bios also can not detect this is hardware problem...
Posted on May 28, 2009
Icon of DVD/CD ROM driver of Acer Aspire 4520 doesn't indicate in My Computer pannel and as a result I can't work with the DVD/CD ROM.Please help me.
if you want a shortcut so to get to your cd/dvd's
click start click on my computer you will see your cd/dvd drives right click on the cd/dvd drive you should create shortcut another message will appear windows cannot create short cut here do you want it to create one one your desktop another way to get the cd/dvd drives
click start all programs accessories you will see windows explorer in the list click to open up then on my computer you will see your drive/s click on cd or dvd
you could create a shortcut for windows explorer by right clicking on it send to desktop to create shortcut if you mean that you cant see your cd/dvd in windows eplorer
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
hope this helps
Jun 21, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer 4520 unable to read the CD DVD ROM drive. When it is starting it does detect it, but after it enters Windows it doesn t even show up on the Device Manager. Actions taken: Restore...
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
or if these fail to resolve the problem
It could be a problem with the lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected hope this helps don
Mar 13, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I have a Samnsung SM-352N DVD CDRW Combo drive. But recently the drivers have got corrupted and I am unable to get back my DVD combo drive to work. In the Device Manager, the DVD CD RW drive is shown with...
control panel admistrive tools,computer management,device manager scroll down cd/dvd drives you should see a yellow question mark? right click to reinstall drivers or right click select enable or properties then general to troubleshoot or region select 4 you might uninstall reboot then reinstall
hope this helps
Oct 02, 2010 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My cd/dvd drive is unable to detect any cd/dvd.acer aspire 4520
I do have the same problem, my laptop doesnt detects the DVD writer, checked with the acer support, asked me to check the motherboard and may need to change that.
Jan 31, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer 4520 DVD driver problem
try to update ur BIOS by install this update from here
ftp://ftp.work.acer-euro.com/notebook/aspire_4520/vista/Bios/3632.zip
Jul 25, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
DVD WRITER IS SUDDENLY NOT RECOGNISED & THE DVD ICON IN 'MY COMPUTER' IS MISSING.
Use the net to download driver. Then you can try using your drive. Otherwise your drive may have gone defective itself not allowing windows to see it.
May 12, 2009 | Televison & Video
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)" . You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Nov 10, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My acer aspire4520 laptop is unable to detect my removable cd/dvd drive
You will need to install chipset driver but it will be much better if you reinstall all driver for it.
Acer Aspire 4520 driver for windows xp can be downloaded here :
http://www.drivercabinet.com/driver-acer-aspire-4520-windows-xp/
Nov 01, 2008 | Acer Aspire 4520-5582 Notebook
Acer aspire 5102 with philips sdvd8821 dvdram drive
alright. bubul78, your post is in no way shape or form a solution for the problems given by other users. I too have a acer laptop with the philips dvd drive in it, device manager detects the dvd reader and says it is running with no problems. i can hear the drive read the cd when inserted, tho when trying to access the drive through my computer the window hangs at the hourglass for a min or so, then says please insert a cd. only solution is that something is physically wrong with the drive. ok so solution found, replace the cd drive. but where is acers sight to order replacement parts? poor site navigation in my opinion.
Nov 01, 2007 | Acer (KV.16X04.007) DVD Drive
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Logo
673 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
