Question about Kenmore Washing Machines
Leaking water during spin cycle
I have a Kenmore Elite HE3 washer. It is leaking water from the bottom right corner at the rear of the machine. (This is when looking at the back of the machine.) It is doing this during the spin cycle.
  • 15,935 Answers
Likely the tub seal is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water leaking from bottom of machine onto floor during fill and wash cycle
there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
Water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a top loader kenmore elite washer that is leaking. The service guys have replaced everything from valves, tub ring and the fabric softner dispenser but its still leaking Help
Hi, Did they check the pump seal or the hoses. Does it seem to leak from the front center? Is it leaking while filling or during agitation or spin cycle? Are you getting water every load and is it a little water or a lot?
Please forgive all the questions, I have to ask.
Questions I need to ask in order to assist you as best I can.
Vic
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
228 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
