Question about Philips 60PP9352 60" Rear Projection Television
No power just a chirping noise.
LAST NIGHT I WAS WATCHING T.V. AND THIS MORNING I TURNED MY SET ON AND IT TURNED ON FOR ABOUT 1 SEC THEN IT WENT OFF BUT THE POWER LIGHT STAYS ON AND A CHIRPING NOISE IS COMING OUT FROM THE REAR OF THE T.V. CAN SOMEONE HELP ME OUT WITH MAYBE WHAT IT COULD BE AND HOW MUCH IM LOOKING INTO GETTING IT REPAIRED AND MAYBE RECOMMEND A TECH TO CHECK IT I'M IN CANYON COUNTRY, CALIF
  • Philips Master
  • 3,459 Answers
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Posted on Jan 26, 2009
    Problem Solver:
  • 7 Answers
Two main common failures for these sets is the convergence amps and the flyback transformer (which is rather expensive). Both can make the set "chirp".
Posted on Jan 08, 2008
    President:
  • 4,402 Answers
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 19, 2007
I replaced all of the contractor installed smoke detectors with First Alert Model P1210 detectors.
The replacement smoke detectors may have had low batteries when installed or the contractor-selected mounting locations may be wrong.
Feb 04, 2017 | Heating & Cooling
Good morning Sam. Last night while watching TV the
Hello Andrew, Could I get you to please post the model number and make of the set. I will be better able to assist you.
Dec 03, 2011 | Samsung 56" Slim-Depth LED DLP HDTV
Tv wont turn on just chirps
The power supply in these sets will chirp if there is a short on the secondary side. I would start with the horizontal output transistor. It is really hard to say because everything in the set is run off of this power supply. It would be best to have a technician check this out for you. Thanks for using fixya.
Dec 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Power light blinks red
first try unplugging it and let it reset, for at least 3 minutesthen try it again
May 30, 2008 | Panasonic PT-50LC14 50" Rear Projection...
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
No picture on screen, chirping noise every second from back
again a good set the deflection modules on these sets are pretty reasonable you need to have a tech swap it but i highly suggest that than a new one the chirping is the set trying to start up but going into shut down
Dec 02, 2007 | Samsung HC-P5241W 52" Rear Projection...
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
Sony Trinitron KV-28WS3U Dies
B+ over current protection (OCP), unit goes to the standby mode. Could be a short in the power supply of any of the circuits.
Nov 05, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Philips 60PP9352 60" Rear Projection Television Logo
593 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
