Question about Philips Gemini CDM-500
My gemini cdm-500 comes up with a error wen trying to play a cd on one side
  • 6,784 Answers
HI. i would try cleaning the lens with cleaning disc. if this doesn't produce results, the issue will then be a damaged optical lens assembly. you will need to replace this assembly in this case.
Posted on May 29, 2009
How i can connect a Gemini cdm-3610 to a laptopand which cabes i can use
It depends on what connections the laptop has. Most have an audio in socket. So you can use that. All you need is to find a audio out on the deck. I looked at an illustration and it has an headphone socket. So you could use that. Just keep the volume control low.
Sep 20, 2016 | Gemini Audio Players & Recorders
What inputs do I use to connect my laptop to the gemini cdm 3700g?
if it's to record the Audio you need some kind of interface analog(RCA ) to usb like the behringer UCA 202 Now if it's to watch or to try to record Audio and Video you need to look at a video capture type of interface composite audio video to interface like the SIIG USB 2.0 Video Capture Device just make sure its compatible with your OS. Now if you try to use it as a Midi controller with program like Serato , Virtual dj ... you are out of luck this system is not compatible .
Good luck.
Jul 05, 2014 | Gemini DJ Gemini CDM-3700G Dual CD Karaoke...
How do i fix my gemin CDm 3700g so that it reads my CDs
I would go to radio shack or some electronics store and buy a can of compressed air that comes with a straw taped to the can. Plug the straw into the nozzle and open the CD drive and blow the air into it while moving it back and forth in the slot to blow as much dust as you can away from the laser head and surrounding areas. That should clean the laser head and allow it to read properly unless something is wrong with it. I would try that on any CD/DVD drive before any other steps. When they get dusty, they can't read.
Mar 31, 2013 | Gemini Sound Products Gemini CDM 3600
Player continues to play while in pause-mode
This is a job for a Technician of that brand. The unit is not knowing the pause mode is activated so there may be a bad cable or solder joint linking a mechanical IC to that of the main processor.
Jan 24, 2013 | Philips Gemini CDM-500
One tray on the right side of my cd player will not open Gemini CDM 3600
Typical problem is a little rubber belt that drives the tray carriage from a motor... it slips or deteriorates.
Jan 19, 2011 | Gemini Sound Products Gemini CDM 3600
No Disc
you may need to get a new player because this one sounds broken and can only b temporarally fixed.
Jun 30, 2009 | Philips Gemini CDM-500
Cdm 500 not reading disk 1
First, try the disc that plays OK in deck 2 in deck 1. This will eliminate the disc as the problem. If the disc won't play in deck 1, then the laser pick-up is on it's way out. There is no easy fix for this, it will require the attention of an engineer.
Dec 12, 2008 | Philips CDM-500 2-Disc CD Player
Philips Gemini  CDM-500 Logo
254 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
