Question about Canon NP 6230 Copier
What does error message E711 mean on a Canon Copier NP6230?
The copier will not start up and allow copiers to be made.  It simply asks to be shut off and restarted.  But I get the same response over and over.
thanks for any help!
srj
  • 149 Answers
E711 on the NP6230 points to a DC controller fault. Unless you can get the part literally free, it's not worth replacing - something else could be damaged along with the DC controller and you will not know until you've replaced it. Walk away
Posted on Jul 09, 2009
Does a canon np6230 connect to a computer
Sorry, No. This is an anolog copier and doesn't have any way to hook up to a computer.
Sep 05, 2012 | Canon NP 6230 Copier
Canon IRC2620 Error Code E000001-0004
This is standard error code for Canon and the fuser unit. The error can be reset by being ready to go into service mode quickly. First press the additional function button, then the 2 & 8 keys at the same time and then the additional function key again. The display should change to the service mode screen, indicating " COPIER " and other accessories. Press " COPIER " then accross the top you should see a menu and select "FUNCTION" then select " CLEAR", then " ERR ", then " OK." This will clear the error from the copiers memory. Turn off the main power switch, wait a few seconds, then turn the copier back on. If you continue to have this error you will have to replace the fixing assembly and if it is similiar to the IRC3220 then you ahve only two screws to remove and the whole unit comes out. You will be saving a service call and I do believe the fuser is over $500. I usually don' tknow the prices of items until I have to do a quote for a customer. Good Luck.
Sep 04, 2012 | Canon imageRUNNER C3200 Copier
Does the NP6230 have a hard drive?
No it does not. This is an analog machine and thus did not use hard drives. Hard drives were not introduced into copiers until around the year 2000. The NP6230 is much older than that.
Thank You for using Fixya.
May 18, 2010 | Canon NP 6230 Copier
Where do I get drivers for Canon NP6230
Wich drivers? Its an old analouge copier without print features
Apr 29, 2010 | Canon NP 6230 Copier
Error message
load more papers in your printer or copier to start it again.If it doesn't,ask again
Apr 14, 2010 | Office Equipment & Supplies
What does the message mean "Replace the waste toner container on a canon np6230?
on right hand side is waste toner you should be able to dump it yourself the main problem is reseting the counter.
Go into maintenance mode by depressing the additional function key, then 2 & 8 at the same time, then additionall function key. Select copier, then at the top far left side select counter.
The counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's
Apr 05, 2010 | Canon imageRUNNER 5570 Copier
Getting e711 error message, requires restart and still gets same error
There is a communication error between the machine and one of the accessories.
Turn the copier off, disconnect all accessories (sorter, feeder) and try again.
You may want to reconnect them one at a time to see which one is bad.
Nov 12, 2009 | Canon NP 6230 Copier
Canon np 6035 saya tak menyala tombol start di posisikan on mati sekitar 5 detik mati sendiri
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
Oct 01, 2009 | Canon NP 6035 Copier
Cannon NP6035
check here for the code: just look for the code, doesn't matter what machine type, they use the same code for different types of models
http://www.copier-help.com/copier-help/ecs/canon/eccgp200.html
Jul 23, 2008 | Canon NP 6035 Copier
Canon NP 6230 Copier Logo
265 people viewed this question
old marine
old marine
