Question about Delta Faucet 470-DST Signature Diamond Pull-Out Spray Kitchen Faucet - Blac
DANCO brand generic hose not connecting to supply
I am attempting to replace to pull-out hose for my Delta 470 faucet because the old one broke. Home Depot had a Danco 88266 model replacement that promised to work. It hooks up to the spout end, but it does not appear to fit the copper pipe water supply end, and looking at the old hose, the supply end differs from the one I bought.
  • 62 Answers
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
Posted on Jun 05, 2009
  • Fred Jun 05, 2009
  • prabaakr Oct 23, 2015
    Even the genuine Delta RP 44647 or RP32527 does the same, they do not fit the copper supply water pipe end, because the hole in these Delta replacement hose has a smaller hole than the older original polished chrome metal hose. Called Delta and they do not have a clue, but they think and insist that either of their RPs has to fit as they are right snap-in quick fit hoses contrary to the realty the customers are facing. Does Fixya has any solution to this problem customers are encountering?
Hose assembly
Shut off main water to home. Then check if a clip is guarding the nut to nut threaded connection the use 2 wrenches to un screw.
Cover tools "teeth" with tape or thin rubber to prevent marking on chrome/etc finishes.
Jul 29, 2013 | Delta Model 470: Signature Kitchen...
Do I have to remove the entire Delta kitchen faucet in order to replace the pullout faucet hose? If not, can you give me step by step instructions on how to replace it? Thanks.
Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
Feb 14, 2011 | Delta Faucet 470-DST Signature Diamond...
How can I remove wand to replace hose on Delta signature series 470 model. Can't "unscrew" wand from old hose.
Go ahead and buy the new hose ant it will come with installation instructions and you will see how it comes apart at that joint.
Feb 10, 2011 | Delta Model 470: Signature Kitchen...
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
My Faucet started dripping. I have installed two
Be sure you have the right kit for your faucet. I think there are two types of springs. I usually leave the ball adjustment loose, and tighten the cap. Then I use that little spanner wrench to tighten the ball. Have you used the little wrench to tighten?
Jun 30, 2010 | Delta Model 470: Signature Kitchen...
Need to take the hose assembly out of delta 470 faucet
you need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
Oct 04, 2009 | Delta Faucet 470-DST Signature Diamond...
Delta Faucet 470-DST Signature Diamond Pull-Out Spray Kitchen Faucet - Blac Logo
966 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
