Question about HTC S710 Smartphone
Problem with my htc backlight
My backlight just blacks out at random, but it seems that the majority of the time, the screen blacks out because i press the left soft key. I tried a software update but the problem is still there. please help me, its a sweet phone
SOURCE: TyTN II - Keep the phone screen alice during a call
Received the following reponse very promptly from HTC Support
---Quote---
This is actually a function of the phone and not a fault. It was designed so that when you were on a call and had the phone against your ear that you didn't accidently tap on the screen and open functions or end the call etc. If you wish to access the touchscreen while on the phone you can press the power button on the side of the phone to turn the screen back on. I have attached a 3rd Party Application that allows the screen to stay on while you are on a call. Follow the below steps to install the program. Attached is a patch for the TyTN II screen blackout issue.
This is not an official fix.
  1. Copy the KaiserTweak.zip folder to your pc's desktop.
  2. Connect you device to the pc via ActiveSync.
  3. Use the Explore function in Active Sync to copy the KaiserTweak.zip folder to the windows directory on your TYTN II.
  4. Disconnect your TYTN II from the pc.
  5. Open up file explorer on your TYTN II and go to the windows directory
  6. Unzip the folder to the windows directory on the TYTN II
  7. Run the Kaiser Tweak.exe to install the patch.
  8. Adopt the recommended configs, not the default.
  9. Soft reset the TYTN II by pressing the stylus into the little circle hole on the bottom of the handset.
If it doesn't work first time hard reset and try again. ---End Quote --- Thanks to the FixYa guys for thier intererst in this topic and problem Cheers Corpcc
Posted on May 12, 2008
SOURCE: unresponsive htc tytyn touch screen
i had the same problem, it turned out to be dust caught just under the plastic at the edge of the screen, a finger nail got it out or you could be fery careful and use a sharp flat knife. hope that helps,
Posted on Aug 27, 2008
proton77
  • 1183 Answers
SOURCE: HTC P3300 does not ON
Apologize for the delay in respose, was having a technical glitch at my end too. Well, if the phone is under one year manufacturer warranty , i would advice to take it in for repairs.
If the warranty is void , try hard reseting the phone ...caution before you do hard reset , it would delete all contacts and files that you saved on it after you got the phone.
Refer owners manual on how to reset the phone . If you donot have the same with , kindly lemme know
Thanks
proton
Posted on Oct 30, 2008
SOURCE: HTC touch P3450 is stuck
my htc touch P3450 HAS HANGED EVERSINCE THAN THE CELL DOES NOT START,HOW DO I SOLVE THIS PROBLEM?
Posted on Dec 08, 2008
SOURCE: HTC Touch screen not responding!
sloution: hey friends my htc p3400i was fell a little on bed after that its touch screen used to work ocassionally, i went to repair shop he told its touch sensor has to be replaced in 600/-, i was damm sure my touch sensor might not be damaged so i puchased screw driver set and opened my mobile, there is one site u can find on google which has service manual of all PDA's. As i was thinking the problem was same the connection was loose i tightened it by cello tape as the scew was broken(i think earlier when my screen was cracked the rapirer chaged many things in my ciuitery as it was not looking fresh one, though it was a new phone), and now its working fine....i m too happy.
Posted on Oct 21, 2009
My G1 or HTC dream won't start up beyond the android logo. I have tried removing the battery and or the sim card.. It still does not start up. I tried hard and soft reset to no avail. After the android...
wipe the phone clean remove the battery and out it back in hold the home & power button at the same time untill black screen pops up press ALT and W to wipe & that should fix the problem
Aug 30, 2010 | HTC G1
HTC herm200 phone not working properly.. :(
its just the display problem u can just replace the display and it will be done!
Jul 15, 2010 | HTC Cell Phones
Need to calibrate my phone
click on start,settings,screen or start,settings,power,adjust backlight,screen!
Mar 19, 2010 | HTC Touch Cell Phone (Unlocked) - Soft...
Screen blacks out on certain channels randomly..doesn't happen all the time audio still works the picture just goes completely black for a bout a second then reappears.. very annoying.it's new and it also...
Ur LCD inverter backlight board have problems,just not dead yet.When ur LCD inverter backlight board is dead.U will get only sound and no picture at all.
Feb 26, 2010 | LG 55LH90 55 in. LCD HDTV
Screen goes black but leaves a very faint image. this happens at random times. turming the monitor off and then on seems to fix the problem for a short time
You are losing your backlight. The bulb is probably overheating and dimming out, when you shut it down, it cools off and will relight.
Oct 11, 2009 | Samsung SyncMaster 920NW Monitor
Dell Inspirion Laptop Screen Randomly Flickers, Then Blacks Out
not to get to concerned just yet, a few tips, when you press on the top of the laptop case by the screen area in the back of the laptop do you notice the screen flickering off? and when you let go dose it come back on? if so this can be a faulty wire or bad inverter, they are actually both very simple to fix and relatively cheap fixes.
Aug 20, 2009 | Dell Inspiron 1100 Notebook
If this laptop is only a few monthe old, then it should be still under warranty. I suggest you return it to the supplier for repair or replacement under warranty. If you try to repair it, most likely you wil void your warranty.
If you don't have this choice then read the following info.
You most likely have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 06, 2009 | Dell Inspiron 1100 Notebook
HTC Touch Pro LCD Going black and then sometimes working
is there the "calendar" and "contacts" menu buttons on the bottom of the black screen?
that's what would happen to me. i just turned off the touchFLO 3D on the today screen (by going to settings, then today screen options) and it seems to not go black anymore... even after being untouched for hours.
not sure if the same thing is happening to you, but it worked for me.
Jul 19, 2009 | HTC Touch Pro Smartphone
Backlight went out
the HTC needs to be reflash to correct this issue...so take the phone to a mobile service center to have that done or try sourcing it online.
Jun 09, 2009 | HTC Touch HD Smartphone
Screen will randomly change positions and sometimes turn black
Reset by holding in power slide for 10 seconds.
There are no firmware upgrades available from website. They suggest that you call the Geek Squad.
Jun 05, 2008 | Insignia Pilot MP3 Player
HTC S710 Smartphone Logo
303 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
