Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
I bought the washer from my friend that had it in storage during winter. I didn't put anti freeze in it... now when its hooked up the cycles run , but water is rushing out the back? what busted and what part do i need?
  • 15,935 Answers
Likely just a hose - but pay particular attention to the plastic pump - it may be cracked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Is there a lubricant I can use to unstick frozen pressure washer pump?
If pressure washer got frozen over the winter, the pump is bad. replace! Use winter pump protector during winter storage!
Mar 29, 2016 | Honda 2500 PSI Gas Pressure Washer
What oil do I use in preasure washer pump
Pump gets anti freeze for winter. 4-cycl motor gets the oil called for in the manual. 2-cycles get oil in the gas.
Sep 30, 2014 | Garden
Please let me know the best way to put my car away in my driveway shelter for the winter
Best advice I can give you is to change your oil and anti-freeze. Anti-freeze will break down over time and if you have old anti-freeze over winter, it will go bad, same with the oil. You should also add a fuel preservative into your gas. It will help prevent oxidizing within your fuel system which will prevent any rusting that could harm the engine. Id also recommend, if you plan on driving it any time, to get a battery charger of some sort. Even if the car isnt running, it is still drawing on the battery to maintain several different things. Lastly, Id suggest moving the car every now and then, as the tires will develop flat spots from sitting still for too long. Ill link you a page with some helpful information as well. Hope this was of use to you!
http://www.inmygarage.com/5-easy-steps-to-prepare-your-vehicles-for-winter-storage/
Sep 08, 2013 | Cars & Trucks
Leaking in base somewhere, badly. Can't get any water out of wand either.
Pump leaks are nearly always from freezer damage. Replace pump and always use anti-freeze for winter storage.
Aug 10, 2013 | Black & Decker Garden
How to winterize my gas powered presserwasher
THEY SALE FUEL WINTERIZER SOLUTIONS AT ANY HARDWARE STORE AND AUTOMOTIVE PARTS STORE. AND YOU CAN PUT SOME ANTI FREEZE IN THE PUMP TO STOP IT FROM FREEZING AND CRACKING.
Dec 11, 2010 | Karcher K2.26 Electric Power Washer
How do I winterize the pump....how do I get anti-freeze into it
We don't recommend using anti-freeze, see attached link for the different options to winterize your pump
http://www.wmpcs.com/blog/?p=63
Oct 30, 2010 | Dewalt DPD3100 Gas Pressure Washer
Drain washer pump for winter
Turn off the water at the cold and hot taps. Disconnect the hoses from the taps and the washer and drain them. Lay the drain hose flat on the floor to drain it to a container. With the hoses disconnected and the drain hose flat, start the fill cycle (set to WARM) briefly (15 seconds) to open the inlet solenoid valves and allow water to drain from them. Start the rinse cycle to pump any residual water out of the tub and drain (15 seconds).
OR
Turn off water and disconnect inlet hoses as described above. Pour 1 gallon of RV anti-freeze (for potable water systems) into the tub. Start the rinse cycle just enough to start the drain so antifreeze goes through pump and into drain hose. Before using the washer again, run a small rinse through to flush out the anti-freeze.
Nov 11, 2009 | Office Equipment & Supplies
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
Nov 04, 2009 | Kenmore 22422 Top Load Washer
Proceedure to winterize washer
HI thanks for your question. the easiest way is to. pour plumbers anti freeze in it 1 gallon should do it . thanks the appliance doc. oh, start it up in the wash cycle for a few minutes, to cycle the water.
Oct 01, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
48 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
