Question about Adobe Flash® CS3 Professional Full Version for PC (38039481)
Text box restriction
This is my question in Flash: how can i restrict the character in input box? I know textbox name with . and we can write restrict script but i need " user should type the letters and then flash should remove the numbers (here i want to restrict the numbers) from the users input text box.
  • 170 Answers
I hope this helps and thanks for rating my effort...any other questions...shoot em to me....The Fang.
Restricting character input You can use the SetInputTextType command to restrict the characters that the user can enter in the text input dialog box. For example, suppose an application contains an input text field for users to provide a numeric value, such as their age, and that the input text field has the variable name ageVar. To ensure that the user enters only numeric values in the text input dialog box, you could add the following code to your application:
fscommand2("SetInputTextType", "ageVar", "Numeric");
When users open the input text dialog box, they can enter only numeric values in the text fields.
For more information, see SetInputTextType in the fscommand2 function entry in the Flash Lite 2.x ActionScript Language Reference.
Posted on May 28, 2009
Usb problems on Jensen vm9215bt unit
Too many subdirectories is most likely the problem.
The stereo may have limitations like 8.3 standard. That means a file can only be 8 characters long with a 3 character extension. Or 256 for folders, including paths. This is old school naming restrictions.
Oct 14, 2012 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Tip
How to recover lost PDF Password
What can you do if you have forgotten password for PDF protected file,it appears"Enter the password".You don't have the password .So how to decrypt password protected PDF Files?
SmartDoctor has released PDF Password Recovery 5.0,software said to recover the passwords of protected PDF documents,even when unusually complicated or long.Successfully unlocked documents are accessible without printing,copying or editing restrictions.
The program supports all character encodings, and can recover passwords entered with any input language or keyboard layout.It is easy to use
1.Click "Open" button of the File Name to browse the full path of the PDF file.
2.On the "Recovery" tab, select "Brute-force Attack (Trying All Possible Combinations)".
3.Click "Start" button in the Menu to initiate the program
4. Some time later, a message box pops up to you, showing the User Password expected. Click "Remove All Passwords from the File" to remove all the restrictions placed on the PDF file. Click "OK".
on Apr 29, 2010 | Computers & Internet
How to check & stop entering special
Use a masked edit control so you can restrict chat is entered into the textbox.
Jan 07, 2010 | Microsoft Visual Basic 6.0 (361-00686) for...
Trying to write a loop using excel text boxes such as: Dim x as integer for x= 0 to 100 textbox(x).backcolor=vbWhite x=x+1 next x Not working any thoughts thanks
You don't say how your program is not working, but one of the problems with your code is where you have x=x+1. Loops using For Next don't need a statement to add 1 to the value of x. The variable x will automatically be increased by 1 each time the program reaches the Next x statement. Your program should be
Dim x as integer: For x=0 to 100: textbox(x).backcolor=vbWhite: Next x
Have fun
Nov 02, 2009 | Microsoft Excel for PC
What if i want user to only enter character in a textbox?
The field should be set as an ALPHA ONLY field! I am talking from the data base side of programming. In data bases you set a field as Alpha, Numeric, or Text. I am not sure if you will have the same options.
Apr 17, 2009 | Macromedia Flash MX Pro 2004
With spaces and exclude spaces
Use the Len function
number_or_characters = Len(your_input_string)
Taking input from a TextBox is easy:
number_or_characters = Len(txtInput.Text)
Mar 04, 2009 | Microsoft Visual Basic 6.0 for PC
Only allowede 70 characters when texting.
Your phone isnt set to the correct character support. Go to text messages and go down the list till you find settings. select text message settings and find "Character support" if its set to "unicode" change it to auto or GSM-Alphabet (Y).. Good luck
Jan 26, 2009 | Samsung J700 Cellular Phone
Vb code for automatic number change
You want the code for when you press enter in textbox it automatically change to 1.
I am typing C# code you can easly covert it to VB.Net code
make an event for key press for textbox
and write the followting code in the event
IF textbox1.text = ""
textbox1.text = "1"
End IF
I hope your problem will solve with this If need more assistance let me know. If your problem is solved then don't forget to make answer my thread.
Regards
Nov 17, 2008 | Computers & Internet
Input textbox
so simple
my_txt.restrict = "A-Z 0-9";
my_txt.restrict = "A-Z";
whatever u can specify in it
Jun 25, 2008 | Macromedia Flash MX
Html codes
What type of order form? My advice would be to use Dreamweaver CS3 but heres a basic form with script that could be easily adapted to an order form.
<%@LANGUAGE="JAVASCRIPT" CODEPAGE="1252"%>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
function verify()
// This section just uses a simple regular expression to check the name
// input box. It checks for one or more characters, a space and another
// group of characters.
if (document.forms[0].name.value.search(/^.+\s+.+$/))
alert("Please make sure you have included your name!")
return
if (document.forms[0].howard.selectedIndex == 0 )
alert("Please tell us what you'd like to do to John Howard!")
return
if (document.forms[0].howard.selectedIndex == 1 )
alert("You'd give John Howard a big tongue kiss? You're weird. Extremely weird. Really very, very, very, very weird. As a matter of fact, you're that sick you can't continue unless you select another option!")
return
// This section also uses a regular expression to check the email input box.
// It checks for one or more characters, then it checks for the email @
// signifier, then another group of characters, then a full stop or period (.),
// then for another group of characters.
if (document.forms[0].email.value.search(/^.+@.+\..+$/))
alert("Please include a valid email address!")
return
else
// If the form is correctly filled out you can submit the form to your mail cgi
// by deleting the next line, and uncommenting the following two lines.
alert("You have filled out the form correctly!")
// document.forms[0].submit()
// return
&lt;/SCRIPT&gt;</SPAN>
</PRE>
<HR SIZE=5>
<H1>The form</H1>
<PRE><SPAN>
&lt;FORM METHOD="POST" ACTION="http://www.your.website/cgi-bin/formail.cgi"&gt;
&lt;INPUT TYPE=hidden NAME="subject" VALUE="Submission from form"&gt;
&lt;P&gt;Name&lt;BR&gt;&lt;INPUT TYPE="text" NAME="name" SIZE=40&gt;
&lt;P&gt;What would you like to do to John Howard?&lt;BR&gt;
&lt;SELECT NAME="howard" SIZE=1&gt;
&lt;OPTION VALUE=0&gt;Please select an option!
&lt;OPTION&gt;Give him a big tongue kiss
&lt;OPTION&gt;Stomp on him while I'm wearing football boots
&lt;OPTION&gt;Beat him around the head with a cricket bat
&lt;OPTION&gt;Make him live in a refugee detention centre for five years
&lt;OPTION&gt;Pour petrol on him and set him alight
&lt;OPTION&gt;Perform explorative surgery on him to discover how he lives without a heart
&lt;OPTION&gt;Ask Buffy to stake him
&lt;/SELECT&gt;
&lt;P&gt;Email&lt;BR&gt;&lt;INPUT TYPE="text" NAME="email" SIZE=40&gt;
&lt;P&gt;&lt;SCRIPT LANGUAGE=javascript&gt;document.write("&lt;INPUT TYPE='button' onClick='verify()' VALUE='Test the verification script!'&gt;")&lt;/SCRIPT&gt;&lt;NOSCRIPT&gt;&lt;INPUT TYPE='submit' VALUE='Submit'&gt;&lt;/NOSCRIPT&gt;
&lt;/FORM&gt;
</SPAN></PRE>
<P></P>
<BR>&nbsp;
</PRE>
</body>
</html>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>Contact Us</title>
</head>
<body><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body>
<h1><span class="style2">Contact Us </span></h1>
<form action="" method="post" enctype="multipart/form-data" name="MyForm" id="MyForm">
<p class="style2">Title: &nbsp; &nbsp; &nbsp;
<input name="Title" type="text" size="15" maxlength="10">
First Name:
<input name="First Name" type="text" size="25" maxlength="25">
Last Name:
<input name="Last Name" type="text" size="35" maxlength="35">
</p>
<p class="style2">Address:
<input name="Address" type="text" size="35" maxlength="35">
</p>
<p class="style2"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
<input name="Address 2" type="text" size="35" maxlength="35">
</p>
<p align="left" class="style2"><span class="style3">Postcode:
<input name="textfield" type="text" size="15" maxlength="15">
</span></p>
<p align="left"><span class="style3">Email</span>:
<input name="textfield" type="text" size="25" maxlength="25">
<span class="style3">Confirm Email:</span>
</p>
<p align="left" class="style2">Contact telephone no. (including area code) </p>
<p align="left" class="style2">Home:
<input name="textfield" type="text" size="20" maxlength="20">
Mobile:
</p>
<p align="left" class="style2">When would the best time to contact you, morning/evening?</p>
<p align="left" class="style2">Comments:</p>
<textarea name="comments" cols="80" rows="15" id="comments"></textarea>
</p>
<p align="center" class="style2">
<input type="submit" name="Submit" value="Submit">
</p>
<input type="submit" name="Clear" value="Clear">
</p>
<p align="center" class="style2">&nbsp;</p>
</form>
<p>&nbsp;</p>
<PRE><PRE><SPAN>
:0) Hope this helps x
May 21, 2008 | Microsoft Office Outlook 2003 for PC
Adobe Flash® CS3 Professional Full Version for PC (38039481) Logo
262 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
