I lost my nakamichi TD45z faceplate and would like to buy a new one. I already bought a TD45 for $30 which isn't the same and doesn't work,so it has to be a TD-45z faceplate.I lost my nakamichi TD45z faceplate and would like to buy a new one. I already bought a TD45 for $30 which isn't the same and doesn't work,so it has to be a TD-45z faceplate.
You can't post conmments that contain an email address.
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
I would recommend taking it back to the pro that installed it given it hasn't been to long. Also the deck should be warrantied and if the front side is not working I would consider that a faulty head unit. I know Nakamichi head units are not cheap.
Go back to the store you purchases it from or contact Nakamichi directly at the link below:
These guys can certainly help you with parts for older Nakamichi decks. They are in the UK, and have most parts for pre 1996 tape decks from the legendary makers. The synthesis chassis had dramas with pinch rollers siezing up from dried grease. I always used to strip and relube, and often replace the pinch roller/tape guide assly. Hit them up, if you have any dramas, get back to me here.
I am more than happy to answer
any other questions you may have about it, just give me a hoy :)
Thanks for using FixYa, If you consider the advice I have given you
as sound, a FixYa rating is a great reward for my efforts to help
you. Cheers.
