Question about Dacor DMT2420 1200 Watts Microwave Oven
DACOR Microwave (DMT2420) Display erratic
Display sometimes is blank, other times is just disfigured. Since it is a wall unit, I have opened the breaker that feeds the unit and that occasionally fixes the problem. Other times when it doesn't, the unit will reset itself unpredictably at a later time. We have had a few power outages, which tells me this may be the result of a voltage transient?? The unit is currently working normally.
    President:
  • 2,992 Answers
Poor solder joints are a common source of trouble on printed circuit boards. You might want to remove the control board and check for poor soldering (grainy joints, cracked solder, occasionally even unsoldered) or cables that aren't seated properly. Also, electrolytic capacitors are a frequent problem in electronic circuits. These are supposed to help filter and smooth out voltage and if they don't do their job you can have unpredictable problems. Capacitors are cylindrical parts around 1/2 to 3/4 of an inch high and around 1/4 to 3/8 in diameter. Look for swollen parts, bulging or split tops (they should be flat). If there are no visible problems the board may have a flaky microcomputer, possibly (as you've mentioned) from power transients. But bad connections are such a frequent thing with current equipment that I'd look for those first.
Posted on May 28, 2009
Dim display light brightness
You will need to replace the display, call Dacor first to see if they will assist in a price break or replacement part. They are normally good with there customers. But there is no way to adjust the display, its just fading over time, like a light bulb.
I hope this helps
Oct 30, 2013 | Dacor DMT2420 1200 Watts Microwave Oven
Electronic panel is not working
You can get that repaired for $39.95 in most cases (details here) or (assuming your model is DMT2420 since that's where you posted) you can order a control / display unit here for a little over a hundred dollars.
Aug 22, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Dacor DMT2420. Light and Display work fine, and you can type in time for cooking, but when you hit start, it does not make the buzz of it's normal sound, and the turntable doesn't spin.
On the DMT2420, that's a bad bottom door switch, or possibly that switch's mount.
The service manual is here and the parts list is here.
You can order Dacor parts by part number from the Pros here.
Jul 22, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
No Display
You can get that repaired for $39.95 in most cases (details here) or you can order a control / display unit here for a little over a hundred dollars.
Feb 19, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
The display panel is scrambled and blinking - can you fix?
Jan 13, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Problem # 1 display goes blank and fuzzy. Problem # 2 Microwave sparks and looks like it's going on fire.
You need display repair ($39.95) and a waveguide cover (assuming your model is DMT2420-something, the cover's part number is 66345, which you can order from the Pros here.
Jan 08, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Light and display work but not unit or turntable
Jun 27, 2010 | Dacor DMT2420SS Microwave Oven
Little chef in display of Dacor DMT2420 microwave is flashing.
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here for a little over a hundred.
Oct 23, 2009 | Dacor DMT2420SS Microwave Oven
Display panel is scrambled on my Dacor DMT2420 microwave.
There are two options for this model:
- You can order our exclusive modified control unit with our proprietary upgrades for $135, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $40.
For details, see: http://www.microwavedisplay.com/exchange.htm
- Or we can repair your existing control unit for $39.95 in about a week with a one year guarantee.
Jan 25, 2009 | Dacor DMT2420 1200 Watts Microwave Oven
Dacor DMT2420 Waveguide
Generally, you are speaking about a cover for this item..I'm guessing...or the unit would not work. If it is the guide...it distributes the energy in the unit. Replace it immediately.
Dec 18, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
264 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
