Question about Sony MHC-881 Shelf System
Erratic CD tray behavior on SONY MHC-881 Shelf system
Hi,The CD (3 disk) tray on a SONY MHC-881 comes out partly on it's own and spins making a noise whenever the unit is turned on. The tuner is in demonstration modeGenerally the CD player has a mind of it own and opens an closes at random times,Al
  • 1 more comment
  • dwcash Jun 18, 2008
    I have the same problem with the CD but nothing else functions on the unit. No tuner or cassette function.
  • Anonymous Mar 21, 2014
    what year did they make this Sony MHC-NX1
  • Anonymous Mar 26, 2014
    The unit stopped working , even when you press the on off button, but the tape drive belts are spinning all the time, strange.
  • 42 Answers
!Precautions/Disclaimer - PLEASE READ!
Whenever you do any work on elecrical equipment always remember: Disconnect the power cord from the wall socket, discharge the remaining electric charge (Power the unit on with the cord disconnected) and always be extremely careful around circuit boards, DON'T touch the exposed circuitry. It might contain lethal electricity! Always read the device specific safety precautions! Do these things on your own responsibility, refer to a qualified technician if you feel unsure about any of the safety precautions. I don't take any responsibility of death or injury! Keep children and animals away from the opened/broken equipment!
On to the issue, Erratic CD tray behavior:
Usually this kind of behaviour is because the unit doesn't recognize the tray as being "locked in". Thus it tries to open and close the tray properly.
There are three main reasons for this:
-Worn and loose drive belts (usually 2x different sized)
-Broken teeth or displacement in one of the gears
-Dirty sensors
  • Disconnect power cable from the wall socket and make sure the unit is safe to operate on (try to power on with the power cord disconnected) wait for about 30 minutes
  • Open the top cover (usually attached to the unit with 4-6 screws on both sides and 2-5 screws on the backside
  • Don't touch the exposed circuit board, lethal electricity might still be present!
  • What you want to look at, is the top area where the cd-changer mechanism is.
  • Check the drive belts for any loosenes (should be minimal)
  • Check the gear mechanism for any loose gears or broken teeth
  • Check the sensors for grease/dust blocking
  • Gently open/close the tray by hand, rotate the revolving tray
The tray is usually locked by the cd-player mechanism that goes up and down, it should move by hand to unlock the mechanisms.
If the belts have a lot of slack in them, you can try to cross them over (shortening by 2x), or get new ones from a radio repair shop/tech. This usually fixes the issue.
If the gears are broken or dislodged, you can try to dismantle the gear unit and turn the broken gear (so that the broken part is not in use) or put the dislodged gear in place. Sometimes a plastic axle is broken and can be replaced with a small screw (drill a small hole and fit a screw in it). You can try to look for spare gears from a radio repair shop/tech, usually hard to come by.
Sorry for the long picture-less how-to, but safety first and more is more :D
Posted on Feb 13, 2015
Change cd head
Posted on Nov 27, 2007
I have a Sony MHC-771 mini stereo system with a 3 cd disk tray. I need to replace the belt that operates the cd tray? The tray is stuck in the closed position. Any suggestions?
Remove the belt and measure it in MM. The search for a belt at that size with Google. You don't have to be too precise about the size. For example if it is 48mm than a 50mm belt should do the trick. Don't bother with the maker's name either. Then can be universal. As long as it looks right.
Jan 30, 2017 | Sony MHC-771 Shelf System
Sony mhc- rg 55 MECHA ERROR disc spin then turn off
My mhc-rg 55 shelf system reports a Mech error when I turn it on (after rotating the CD tray to try to take up each CD twice ) Then is shuts down.... I took the unit apart and saw noting obvious... (Of course it was more difficult to reassemble and still doesn't quite fit properly.) But the problem persists. Looks like it over to the repairer. Sorry - No solution here
Nov 21, 2012 | Sony MHCEC99 Mini MP3 hifi system Shelf...
Sony 3 disc changer mhc-gx880 has broken belt. How to manually eject disc tray?
You have to open the unit with screws in the back and push it out by hand, there should be a series of gears that you have to spin for the tray to come out. You may be able to gently push it by hand to come out.
Jan 24, 2010 | Sony MHC-RV888D Shelf System
Sony MHC 881 -How do I get out of Demo Mode?
Press the Display/Demo button. The power cord needs to be plugged in, but the power must be OFF.
Sep 01, 2009 | Sony MHC-881 Shelf System
3 disk sony stereo
take of the top of the unit. Press open, listen to hear if a motor is running, if so the belt could be worn, change belt, also mechanism could be out of alignment.
Aug 07, 2008 | Sony MHC-881 Shelf System
Sony MHC-RG222 cd player broken
It is not clear from your post that whether this is functioning perfectly other than the sound problem, if it doesn't, change the laser pick up.
Feb 14, 2008 | Sony MHC-RG222 CD Shelf System
Sony VGN-T350
hi , please be specific, is the tray not opening, or there is a NO DISK error???let me know,
Dec 30, 2007 | Sony MHC-881 Shelf System
870 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
