SOURCE: Brother IntelliFAX 2920
What is the error code? I suspect something is barging in on the line. Try it on another line with nothing else attached.
SOURCE: my fax will not automatically redial when it gets
please go to this link and setup your redail time. fax will not redial if your are sending fax in manual mode.
http://www.brothersupport.com/Facsimile/ALL/UG_FAX2820_FAX2920_MFC7220_MFC7225N.pdf
SOURCE: Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
SOURCE: No manual to "Brother Super G3 336kbps IntelliFax-2920"
It is telling you the fuser unit needs replacement. Thats the heater that fuses the toner particles to the paper by heating them. If it cannot reach the correct tempurature the toner comes right off the paper.
So you will need to order a fuser wire kit to fix that error. That can be fairly expensive on a brother. I believe somewhere around $150 and up.
I can at least help you get a replacement manual. This link takes you to the downloads for your printer and you can then download the various manuals.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_top.html?reg=us&c=us&lang=en&prod=fax2920_us
SOURCE: Brother intellifax 2920 will not print from Mac OS 10.5.8.
Reinstall drivers or update them to newer version. If that fails try to reset the printer. Also, download the Brother Intellifax 2920 user manual
Press Menu/Set, 2, 4, 1.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
To print a report
1 Press Reports.
2 Press ? or ? to select the report you
want.
Press Menu/Set.
