Question about Xerox Phaser 7300DN Laser Printer
Image unit reseat
Continous request to reseat Magenta Image unit
  • janegarth May 11, 2010
    I was having problems with the magenta and cyan sensors. I replaced all the flags and am getting a reseat or replace black toner cartridge. I changed out flags per youtube video. What next? thx!
  • Michel Aug 08, 2012
    I have described a reliable cure for this problem on my website - take a look at www.michelsplace.co.uk/xerox-7300.html
    Problem Solver:
  • 5 Answers
Under the hood, between the LED rasterizers (four of them, one for each of CMY & K), there are rockers with a small but powerful magnet. When the lid is closed, the magnet will touch the top of the toner cartridge, which in turn, has a magnet on a rod that goes up and down with the rollers when the toner is churned in the cartridge. If the toner magnet is not in the position it is supposed to be (you can check it's position with a hand held magnet), the sensor will falsely interpret that no cartridge is present. You may need to replace the toner cartridge.
Or if you have more time than money, empty the toner cartridge into a clean vessel, disassemble the cartridge, fix the magnet-on-a-wire assembly, reassemble the cartridge, and replace the toner from the holding vessel. It is possible that the magnets are getting weak, so check them, both on the rocker and on the cartridge.
On the other hand, I've noticed the rocker switches get sticky in lower temperatures (I keep my 2135 in the garage). Maybe a shot of WD40 on the rocker would help, but to do that, you'll need to remove the lid. It's not too hard, there's only about 9 screws, after removing the back panel (another 4 or 5 screws), After a few more screws around the toner sensor panel (a PCB), you disconnect some quick-disconnect switches, and then you can see the rockers (the actual switches are opto-electrical components on the PCB, you might clean them with alcohol, but they are discrete packages that can't be repaired).
This is a major flaw in the Xerox 2135 (probably persists in the 7300 series as well) and the OKI 9200/9300 series upon which the 2135 is based. There's way too much that can go wrong, but the killer is that nothing except the sensor is failing. Very frustrating!
Posted on Nov 18, 2011
  • 87 Answers
Check out the suggestions on my web page article :
http://michelsplace
Posted on Mar 02, 2011
    Novelist:
  • 110 Answers
Chekc out my tutorial on YouTube. Search for Xerox 7300, or Toner Sensor Flag replacement. The Flags in the top cover are likely causing this issue. They "bounce" too much and the printer cannot handle this "bouncing" and shoots out an error. It is either tha Toner Sensor Flags, The Toner Sensor Board, the Engine Controller Board, or the Top cover itself.
Replace the parts in the order I have listed.
Also it could just be a Magenta Toner Cartridge is bad, because the magnet inside the window on the top of the cartridge may have gotten weak over time, and isn't allowing it to actuate the flag in the top cover.
VERY COMMON ISSUE. usually easily fixable
Posted on Feb 19, 2010
In the magenta image unit Vg and Vdc is very high. I change imaging unit-hv1-hv2 but problem did not solved
If Vg and Vdc are very high and you have confirmed that all contacts with the magenta image unit inside the device are clean and making solid contact with the imaging unit, you may have to replace the High Voltage Power Supply (HVPS) as it is passing too much current to the unit.
Jan 18, 2016 | Konica Minolta Bizhub C652 Color Copier...
Malfunction C2553
Open close front door to reset. But your Magenta Image unit is having issues remove and shake the unit side ways to spread developer and toner whole length of the unit. Worse case get a new magenta image unit.. Also clean the sensor below the image unit when pulled out all the way near the front of the copier each color has one except black.
Mar 22, 2015 | Konica Minolta Konica Bizhub C250 Copier
Magenta cart. wont print
The problem is most likely a bad Image Unit.
Xerox guarantees their supplies to be free from defects as long as their is a life percentage left and will replace it for free.
Take it back to the store you purchased it from and ask for a replacement, or have them request a replacement for you.
If the magenta fails (within 100 pages) after you replace the Image Unit, then your toner dispense mechanism is failing for the magenta toner, and either a dispense motor will need replaced, or the toner auger will need to be unclogged or replaced.
Jan 28, 2014 | Xerox Phaser 6360 Laser Printer
How to clean the magenta toner out of the drum unit
Change the magenta image unit,your image unit life end,
Feb 28, 2013 | Canon Color ImageRunner LBP5970 Laser...
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
It is leaving heavy blue streaks on everything printed
Hey, blue streaks could be a few different things. The first thing I would check is the image unit. Try swapping out the cyan(blue) image unit with another color, such as magenta. If the streaks change from cyan(blue) to magenta in color then you know the image unit is bad and must be replaced (part # 108R00581). If it is not the image unit then it most likely is the developer. The developer takes about 40 minutes to install and really should be done by a service technician.
Here is a video that shows you how to remove the image unit and where you can purchase one.. Just go to 57 seconds in the video. Hope this helps, good luck!
May 17, 2011 | Xerox Phaser 7750GX Laser Printer
Sir, i am using Konica Minolta C252. I am getting error message C-2553. If i opened the front door and closed then the error message will go, but again it will come after some copies. What is the problem...
Magenta Image unit mite be the problem have it replaced if it already was then mite have a bad new one also check the sensor that monitors the toner for the magenta Also pull out the magenta image unit shake side to side to spread out the develop inside the image unit along the entire length of the image unit reseat the image unit.
Aug 20, 2010 | Konica Office Equipment & Supplies
Falal error 173 on oki c5650 after changing fuser unit
Cause:
This error indicates that the Image Drum Up/Down Process is not working properly.
The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Resolution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
http://my.okidata.com/PP-C7200.nsf?opendatabase
Apr 23, 2010 | OKI C5650n LED Laser Printer
Image ghosting only on magenta
If the ghost is only on the magenta, your imaging unit is to blam.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 08, 2009 | Konica Minolta bizhub C250 All-In-One...
Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Jul 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
456 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
