Question about Canon PowerShot A610 Digital Camera
Protective lense shutter is stuck partially closed, causing black corners in the photos. How do I fix this, or remove the shutter completely?
My Canon A610 has a lense with the protective shutter will not close, it is stuck partially closed and causes black spots on the outside of the photos. How do I remove the shutters, or remove the lense to repair it?
  • Canon Master
  • 4,738 Answers
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But for the A610, you might want to extend your zoom all the way out before removing the camera's batteries. Note that the A610 has four shutter leaves instead of two, so pay particular attention how they're assembled if you remove the lens ring. Also you'll be applying the ring loosening rubbing alcohol around the barrel's perimeter instead of the front as shown in the procedures. One other thing, try not to get any alcohol on the lens itself:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Good luck, and remember to do this only as a very last resort (try the other listed procedures first). Oh, and if you do decide to try the repair, please post how it went.
Posted on May 28, 2009
Shutter will not open every time i take a photo. The photo always comes out black on the view finder
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 27, 2011 | Cameras
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
The screen of the camera works only for setting and menus, but for shutting photos the screen is black. No more photos could be taken. I seems to be taking photos but all of them are black. But I heard...
And here you go, this should help. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 29, 2010 | Canon PowerShot S2 IS Digital Camera
When i turn on my camera the lense extends but you can not see thru neither the lense or the remote screen. please help
Jul 15, 2010 | Canon PowerShot S2 IS Digital Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
Photos come out with black stirp on top when developed
OK . . . I don't think that this site is designed to generate phone calls.
However, I can tell you that your camera needs to have the shutter replaced. The price for this service can vary widely depending on just how much damage has been done. You may be better off simply replacing the camera.
The problem is that the shutter is not opening completely due to the bent blade. This causes part of the film area to remain unexposed and print black on your photographs.
Nov 19, 2009 | Konica Minolta Cameras
View screen black when on & no longer takes photo's
Sounds like a dead CCD. Contact your local Canon service center.
Tom
Jul 24, 2009 | Canon PowerShot S3 IS Digital Camera
Canon Powershot A510 black screen when taking photos
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
When powered up, "Remove lens cover, press button"
The symptom of "remove lens cover" always showing can be caused by two different things. If the lens assembly has become jammed and will not move when the camera tries to extend it - this can cause the message. On some cameras a stuck-closed shutter can cause this message as well. The symptom you describe of seeing two images prior to the failure is strange. I cannot make any kind of conclusion from that information without further elaboration. Does the lens extend when you turn the power on? If not the lens is jammed. Do you see nothing but black all the time on the screen and the captured photos? If so the shutter is stuck closed. Either of these problems will require complete disassembly and re-setting of the lens elements. Check with your manufacturer and see if they will fix it under warranty. If not, there are service providers available on the internet who can service your camera. David Millier Advance Camera Repair
Feb 27, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Digimax i6 pmp SHUTTER problems!!!
Congratulations on fixing the problem! However I just wanted to let you and everyone else who reads this solution know that the part which failed on your camera is not actually the shutter. The shutter is deep inside the lens assembly right next to the image sensor. What you were dealing with was simply a protective cover for the lens. David Millier Advance Camera Repair
Feb 03, 2007 | Samsung Digimax i6 PMP Digital Camera
Canon PowerShot A610 Digital Camera Logo
524 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
