Question about IBM ThinkPad 600E 2645 Notebook
Trackpoint Malfunction the pointer will move by itself very rapidly and is extrenely sensitive. All of the settings are appropriate. How do I repair or take out the trackpoint for clean and repair?
    Novelist:
  • 166 Answers
You are lucky that you have IBM machine. They provide a facility of RESTORE TO FACTORY SETTINGS.
Using it all such misappropiate settings will get cured and your machine will work like a BRAND new machine.
Also regarding your mouse sensitivity, you can go to CONTROL PANEL & then to MOUSE settings & there you can customize your mouse settings (sensitivity also).
Rate the solution if it was helpful to you...
With Regrards,
Shyny
Posted on May 28, 2009
    Problem Solver:
  • 5 Answers
Many IBM and Dell laptops that have the 'trackpoint" aka pencil eraser head between the G and H keys of your keyboard that control your mouse cursor cause this problem
cheap fix OPTION #1) is to remove the keyboard and cut the ribbon cable that attaches to the trackpoint. Voila ! Problem solved if you dont mind using an external mouse, but next option is more realistic
OPTION #2) Buy a keyboard cheap on eBay. Search: IBM 600 thinkpad keyboard. Easy to replace. See this link, easy for even a novice
http://www-307.ibm.com/pc/support/site.wss/LWIK-3SYPX2.html
Hope that helps !
Posted on Jul 11, 2009
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
I have a TOSHIBA NB100.The mouse pad is too sensitive .I can even move the cursor hovering my finger above it without touching the pad .I thinlk it causes words and letters to come out as a jumble. Is...
control panel----Mouse----Should bring you to a screen with several tabs at the top-----pointer options tab---Select a pointer speed this should slow down the mouse movement----then go to the first tab (touchpad) and you can change the touchpad sensitivity. Hope this helps
Jan 07, 2011 | Computers & Internet
Hi, my acer 3820TG touch pad seems to be too sensitive is there away to calibrate it?
Hi jace_bingzho,
You can adjust the sensitivity of the mouse according to your requirement. Just follow the instructions below:
1) Click on Start.
2) Go to Control Panel
3) Double Click on 'Mouse'.
4) The Mouse Properties dialogue box pops up.
5) In the pointer options tab, under Motion, there will be a slider under 'Select a pointer speed'.
6) Move the slider with your mouse towards 'Slow'. Now you will notice that when you move your mouse, the sensitivity has decreased.
7) Apply the settings and Click OK.
Hope this information was helpful.
Thank you for using fixya,
Arun Zac
Nov 26, 2010 | Acer Computers & Internet
When mouse pointer is set to go to default box it does a runner!
check the mouse sensitivity settings under control panel.
Oct 06, 2009 | Computers & Internet
The pointer freezes or starts moving about without any reason, especially when my laptop is carried from one place to another
this is not a software driver issue... many IBM and Dell laptops that have the 'trackpoint" aka pencil eraser head between the G and H keys of your keyboard that control your mouse cursor cause this problem
If your laptop has the TOUCHPAD and the TRACKPOINT cheap fix OPTION #1) is to remove the keyboard and cut the ribbon cable that attaches to the trackpoint. Voila ! Problem solved if you never use the trackpoint (most people use touchpad instead anyways) or you can use external mouse as well. Next option is more realistic for most people...
OPTION #2) Buy a new keyboard cheap on eBay. Search: IBM T42 keyboard. Easy to replace. See this link, easy for even a novice
http://www-307.ibm.com/pc/support/site.wss/MIGR-46515.html
Hope that helps !
Jul 09, 2009 | Lenovo IBM ThinkPad T43 Notebook PC -...
Mousepad, right clicker problems on ibm thinkpad t41
you can try looking at the manufacturers website for a driver update to your trackpoint http://www-307.ibm.com/pc/support/site.wss/MIGR-46258.html#mouse
Try turning off the tap to click option. This should resolve accidentally dragging things where they don't need to be.
Better option...if you're using this laptop at home just invest in a wireless mouse and set the laptop to disable the trackpoint when an external mouse is detected.
trackpoint=mousepad=touchpad
Jun 10, 2009 | IBM ThinkPad T41 Notebook
Mouse pointer seems to randomly move around the screen
The problem is in the trackpoint itself, it is defective. The fix is to either disable the function of the trackpoint through software or by physically disconnecting it.
Disabling through software can be done usually through the BIOS or in the Control Panel in windows. If there is no way for you to disable it then you have to remove the keyboard and cut the connector that is coming from the trackpoint control board. Make sure that you do not cut the keyboard cable. The trackpoint cable is usually about 4 wires thick and is seperated from the thicker keyboard cable. The only other thing to do is to replace the keyboard.
Apr 03, 2009 | Dell Latitude D410 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
324 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
