Question about Canon imageCLASS D880 All-In-One Laser Printer
Dialing option for Canon D880
My office is located in Richmond Hill, when I dial a fax number area code 905, the fax machine don't automatically dial 1 before the number if it is long distance. Is there any option for this? What is the following option for?
1) One Touch Speed Dialing
2)Coded Speed Dialing
3)Group Dialing
4)Directory Dialing
    President:
  • 1,126 Answers
Http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=124&modelid=10516#DownloadDetailAct
Under Drivers and Downloads tab. Fax Guide, Chapters 3 and 6 should shed some light these issues.
Posted on Jun 07, 2009
Do I have to dial 9-1 before the area code when faxing?
Hello, If you are in an office or corporate environment where the phone system is on a PBX you need to dial 9 usually to get outside the office. If you just have the unit setup at home or to an analog phone jack (not going thru a PBX) then just dial 1 + area code + number. If the number is local then don't use a 1, just the phone number and area code.
Chris
May 11, 2011 | Ricoh Aficio CL3500N Laser Printer
Hello, We can receive faxes but can no longer send faxes from our HP laserjet 3390. The display window shows a 9 infront of the number we are trying to fax, dials that number and then does not complete...
You have to go into the settings on the fax machine. There will be an option for a prefix number. Someone put a 9 in there. Having the 9 in there will make it dial a 9 then the number you are trying to faxt too. Remove the 9.
Mar 03, 2011 | HEWLETT-PACKARD Office Equipment &...
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
How do I set and save a fax number as a speed dial
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
Sep 22, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do i store numbers? there is no manual.
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
TELEPHONE NUMBER
TEL =
Sep 17, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do I save a number
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON CFX-L4000.pdf
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
• You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
• If a number is already stored at the button you select, that number appears.
• If the button you select is registered for Group Dialing, GROUP DIAL appears.
TELEPHONE NUMBER
TEL =
• Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
• If you want to clear a number or a mistaken entry, press CLEAR.
• To enter a pause in the number, press PAUSE one or more times
Aug 19, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I need the instructions for the mounting bracket for the stoney point bipod.
Contact them at the appropriate number listed below:
hope this helps, Mark the Gunsmith UNITED STATES
Bushnell Outdoor Products
9200 Cody
Overland Park, KS 66214-1734
In Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
CANADA
Bushnell Corporation of Canada
25A East Pearce St.
Richmond Hill, Ontario L4B 2M9
Local Phone - (905) 771-2980
Other - (800) 361-5702
Local Fax - (905) 771-2984
Other Fax - (800) 661-3254
Dec 25, 2009 | Stoney Point Optics
I have a 3 x 9, the dial used to adjust from 3 x to 9x is stuck on 3x and won't turn
Either the scope is damaged or a screw is missing.
Contact Bushnell below: United States
9200 Cody
Canada
25A East Pearce St.
Dec 04, 2009 | Bushnell Optics
Why is it when I am sending a long distance fax to another state I receive a code that says G3.
There are several reasons this could be happening.
  1. Does your office allow for long distance dialing and if it does, do you need to "Dial 9" or some code before dialing long distance?
  2. Have you dialed "1" before the area code?
  3. Is the area code correct?
These are the most common reasons why you would get a long distance error while faxing. Hope you find this useful.
Nov 16, 2009 | HP 1040 Plain Paper Inkjet Fax
When I try to send a fax I must dial 5 then number, do I have to put the area code if it's the same? and it says dialing then no answer. Does this mean it is actually trying to send the fax? (military)
It never hurts to use the area code in some places it is necessary.
No answer either means you are dialing a number that isn't a fax or the fax you are dialing is not set up to auto answer.
Try a fax you know is working.
DickyO
Oct 20, 2009 | HP FAX 1250 Fax Machine (Black)
Canon imageCLASS D880 All-In-One Laser Printer Logo
75 people viewed this question
old marine
old marine
