Question about Microsoft Xbox 360 Console
MTU con connecting. How to fix ?
Setting up new X Box 360 live. All show connected except Mtu. It shows faied.  How do I repair this ?
  • Anonymous Sep 28, 2008
    My xbox is new and I want to connect to xbox live but my mtu wont connect.
    Scholar:
  • 110 Answers
What does MTU do on Xbox Live?
The MTU of your router or gateway must be greater than or equal to 1365. If it is less than 1365, you won’t be able to connect to Xbox Live.
To change the MTu login to your admin router panel:
  1. Go to start>Run>cmd>type ipconfig
  2. look for "default gateway" then type that address into your router login, usally the login is admin/admin if not look in your manual or call your router maker.
  3. Now login locate the area to adjust the MTU if you cant find it, contact the router maker, or look in your manual.
More info:
http://www.xbox.com/en-US/support/connecttolive/xbox/connectionmethods/diagnosingconnections.htm
Cam
Posted on Oct 22, 2007
Tip
Xbox Live - MTU Error
Xbox 360 MTU errors
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
on Sep 30, 2008 | Microsoft Xbox 360 Console
Not enough mtu to go to xbox live at hotel
An MTU is the largest physical packet size, measure in Bytes that a network is capable of transmitting.. If messages are larger than the MTU they are divided into smaller packets before they can be sent. All networks have different MTU's which the owner of the network set at what they want to set it at. 576 is a very common MTU if you connect through PPP. 1500 is the most common MTU for Ethernet connections. The Xbox Live system requires your network to have a certain Maximum Transmission Unit (MTU). MTU values are important to the performance of online games. If this test fails, you can adjust the MTU setting on your network router or equivalent device to resolve the problem. Xbox live requires the network you use to have a maximum MTU. This is key to online gamesing. If the MTU fails then you have to adjust the router you are using. If you cannot access the router to adjust the MTU the you will not be able to play online games.
Mar 22, 2011 | Microsoft Xbox 360 Console
Trying to set up xbox live.
you need to make an xbox live profile not mtu for offline. You have to make a new profile.
Jun 23, 2009 | Microsoft Xbox 360 Console
Mtu settings
Two things needs to be cleared:
1) Which connection did you talking about LAN/WAN?
2) Xbox live may not be up yet, can you verify it?
Most home gateway routers can only change WAM MTU for certain connection type (PPPOE), and cannot set MTU for LAN and other WAN connection.
To change MTU for PPPOE, going to WAN connection setting, and you will see the MTU options box. But do not change it unless your ISP told you to do so.
So make sure Xbox live is online -- I am no Xbox fun so I have no idea how it works, but just guess from your message.
Jun 19, 2009 | Belkin (F5D7633UK4A) Wireless Router
Xbox live cant connect mtu failed
This appears to be a common problem, most likely due to the recent Xbox Live server maintenance. Nothing we can do except for wait until Microsoft fixes things on their end.
MTU setting
Browse to the router's setup page, should be 192.168.1.1 or 192.168.1.0 and log into it. You just have to change the MTU. Put it to 1500.
Once logged in to the router, go to :
Setup
Basic Setup
Wireless Setup
Internet Connection Type
Connection Type = Static IP
Internet IP Address = 192.168.0.1
Subnet Mask = 255.255.255.0
Gateway = 192.168.0.1
Static DNS 1 = 192.168.0.1
Static DNS 2 = 192.168.0.1
Static DNS 3 = 192.168.0.1
STP = Enable
Optional Settings (required by some ISPs)
Router Name = client-mode
Host Name = 2WIRE383
Domain Name = [empty]
MTU = Auto
Please remember to rate all users who assist you for free :)
Sep 29, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
Mtu test is failing
I've had the same problem and struggled with it for hours... If your on the Comcast network, there seems to be problems with adjusting MTU. I have a Dell 2350 router and that particular router cannot have MTU modified. Also, sometimes the MTU is effected by computers or phones in the house being on. One more suggestion, try a gaming router. Good ones start at 90 dollars, somewhat expencive but well worth it.
Jun 03, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 live states MTU failed
for some reason i cant connect to live, it says that my mtu has failed. any surgesstions how i solve this??
May 18, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
281 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
