Question about Panasonic PT-52DL10 52" Rear Projection Television
Spots on picture screen,color not correct
T.V. says red bulb is bad
  • 464 Answers
The picture tube has three color production units (bulbs) red, yellow and blue.....since these three colors can be combined to produce almost any color. as you have specified the red bulb might have damaged due to one of the following reasons.
1.continuous usage
2. keeping your tv in standby mode for a prolonged time.
the only thing you can do is call a technician and get your damaged part replaced.
remember please do not try to disassemble the unit yourself.
Posted on May 28, 2009
After lamp replacement, why is picture still green?
it seems like the green was not defective before you replaced the green. remove the red =no change in the screen color, that could be bad. put back red, then remove blue=screen color changed, blue is good, hope you got the idea.
Oct 08, 2015 | Sony Televison & Video
Colored spots on Samsung HLP5063W
The color wheel or the DLP chip itself will cause this. Parts can be had here: www.shopjimmy.com
Jun 27, 2017 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv is yellow orange color what is problem
The model indicated does not have a "bulb" as it uses 3 picture tubes.
Examine the picture with color set at zero---stand back and look= if the screen has a mostly yellow (all or part of the screen) you have bad Glycol in the blue picture tube(if need explanation ask) and a look in the lens of the Blue tube will confirm this.
If able with back off and a small mirror look in each lens--red picture, green picture and blue picture.
If the Blue looks like a floodlight with little or no image--bad glycol in that tube.
Jun 16, 2012 | Samsung HCN5527W 55" Rear Projection...
When the screen has a light picture you see pink color bloches all over the screen, when the picture is darker it's not that bad. It all started a few months ago with different colored spots on the screen.
Howdy,
The problem is with the EEPROM in the TV that needs to be reprogrammed. But you need to have the proper Correction Tool (LSUQ0100).
I don't think it's available to the public. Call a Service Company, but make sure they have the “Correction Tool”.
Thanks for using FIXYA, big IRISH.
Dec 27, 2009 | Panasonic PT-44LCX65 Television
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Two color variant spots in the middle of my Sony KV-34HS420 34 in
your tv needs to be degaused or demagnetised.it cant be a bad picture tube unless it was dropped.
you can call a local shop to degause it in your home.rather easy and inexpensive to fix.
Sep 24, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Apr 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Spots on sreen
Your spots on screen is normal, which is called color spots.Those were often found on crt tube, where discharge to grounding is slow.
Rdgs
Alan
Feb 24, 2008 | Mitsubishi WS-55807 TV
Color wrong and red spots
Sounds like CCD sensor problem . It starts with 'noisy' pictures ( colors not true and resolution deteriorates )but eventually the sensor stops outputting anything and you end up with blank screen. Have the sensor replaced and camera will work fine.
Sep 11, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Panasonic PT-52DL10 52" Rear Projection Television Logo
183 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
