Question about Vacuums
CLEANING SOLUTION WILL NOT COME OUT - Vacuums
  • Vacuums Master
  • 19,396 Answers
That can happen because the lines got clogged, after cleaning solution residual has accumulated inside lines. Try running the vacuum with distilled water inside for a while.
I can be more specific if you give me make and model.
Thanks.
Posted on May 28, 2009
How can you clean spots off carpet
Office pros cleaning service is expert in carpet cleaning.They categorize our cleaning program depending upon carpet condition. Offer three types of carpet cleaning programs.
Steam clean/ Hot water extraction
Bonnet clean
Very low moisture encapsulation clean.
Office pros cleaning staff expert in spot and stain remove from carpets,use the green certified product for cleaning.So finnally I suggest for Office pros cleaning for remove the spot and stain from carpet.
Commercial Office Carpet Cleaning
Dec 30, 2013 | Vacuums
Cleaning oriental rugs leaves lines on some rugs
Hey Jeff! Some Oriental rugs should not be cleaned with water. You may want to contact the manufacturer of the Oriental rugs regarding their care instructions.
Mar 04, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
How much for a weekly cleaning service?
The rate of cleaning services are different from company to company and from the condition of your house. Generally cleaning services in a week is not costly if you get regular cleaning services because in this situation your home will not too more dirty therefore the cleaning service provider charge small amount. You have heard that health is wealth and most of us has done this experiment. When we become ill we do not be able to continue our work as well as it affects us mentally too.There are many health issues increasing day by day , hence it is necessary to concentrate on the home cleaning.
NEW YORK CLEANING SERVICE
Nov 29, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to hook up tool to clean upholstery
Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
  1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
  2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
  3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
  4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
  5. Step 5 Remove cushions and, if necessary, arm covers.
  6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
  7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
  8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
  9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Brush cleaning, wheel thump
rchu is exactly right. No need for a complicated disassembly. If you have never pulled off those end bearings/caps, the hair may be very impacted, but removing it should solve the problem. The instructions will tell you by color (yellow for mine) which pieces come off for cleaning. Be sure to remove all such pieces. If the fit seems tight, it's probably because a lot of stuff got stuck in there. Be gentle but firm, and things the should come off will come off. Once you've cleaned all the pieces, the thumping should be gone.
Nov 14, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
