Question about Sony RM-Y187 Remote Control
PALETTE  and mode buttons do nothing
  • 4,102 Answers
This is usually because the controll has got damp or has got dusty inside the best thingto do is take the case of and clean the back of the buttons then with a dry cloth wipe the board where the buttons press this should solve your problem but as this controll work on different things maybe you dont need to use these buttons so unless oyu need to you use them leave it as it is hope this is some help
Posted on Oct 31, 2007
How to program JVC Remote RM-SXV067A Remote to TV
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jun 20, 2012 | JVC RM-A5 Remote Control
How to make a digital copy
o do this:
Press the power switch. (Capture mode)
Press the Play button. (Playback mode)
Press the four-way controller (down). (Playback mode palette)
Press the four-way controller (right) 3 times to select [Image/Sound Copy].
Press the OK button to display the screen for selecting the copy destination.
Press the OK button to copy the data.
Press the Play button or press the shutter release button down halfway to return to Capture mode.
Playback Mode Palette Copy destination selection
* This function can only be selected when an SD (SDHC) Memory Card has been inserted in the camera.
Jun 11, 2012 | Sylvania Hd1z Sdsdhcmmc 720p Hd Pocket...
I cant find a code or how to program my sony RM-Y187 remote to my Dynex DX- DVD2
If your remote is older than the Dynex, there may not be any code set for it built-in and if it is not a 'learning remote' it may not do what you want. Your best chance for a code listing will be on the Sony website.
Jun 02, 2011 | Sony RM-Y187 Remote Control
Cars game only has one player as an option, how do I open/unlock 2 player mode? Tried 1 and 2 on second remote, nothing happened.
  • From the Disney/Pixar Toy Story Mania! opening screen, press the 1 button on Player 1 Wii remote to start.
  • At the "How many players?" (color palette) screen, point to the number of players (1 through 4) and press the A button.
  • Point to the desired color for each player and press the A button on the corresponding Wii remote. The player's number will be displayed in the color (for example: 1 in yellow, 2 in purple). Point to the green arrow and press the A button to advance.
  • At the name entry screen (Mr. Spell), starting with Player 1, point to the letters and press the A button to select. Once Player 1's name has been entered, point to "Enter" and press the A button to advance to the next player.
  • When all players' names have been entered, you may select from Story or Freeplay mode to begin playing. Freeplay mode will only contain games that were previously unlocked in Story mode. For more information on Disney/Pixar Toy Story Mania! game modes, see the game manual.
  • Mar 21, 2011 | Disney Cars Toon: Maters Tall Tales for...
    How can i activate a remote for a mercury mariner 06?
    Do not press brake pedal during Remote Entry programming procedure as it will immediately exit you from
    that mode. Electronically unlock the vehicle prior to attempting to enter Remote Entry Programming Mode.
    Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. All doors will lock
    then unlock to confi rm programming mode. Within 20 seconds, press any button on 1st remote transmitter.
    Door locks will cycle to confi rm programming. Within 20 seconds, press any button on 2nd transmitter (up to 4
    transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
    Mar 10, 2011 | Mercury Mariner Cars & Trucks
    My remote rm-u306 will not turn on my system but it will turn it off when i press the stand by button and the off butten together
    I had the same issue. To fix it, on the receiver i pressed the Set Up button and then the Menu + button to change the input to C.MODE.AV2.
    Jan 28, 2011 | Sony RM-U306 Remote Control
    Car key remote
    1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
    RUN. Door locks will cycle to confirm programming mode.
    2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
    to confirm programming.
    3. Within 20 seconds, press any button on second keyless remote. Door locks will
    cycle again to confirm programming.
    4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
    Mar 24, 2009 | 2001 Ford Expedition
    How do you program the Sony rm-p311 remote
    You may wish to clear the remote's memory before starting. Slide the top left switch to "Learn." Press ANY button on the remote, do not worry if the indicator light flashes. Press the "Program Clear" button. The indicator should flash 4 (maybe 5?) times. You are now ready to program. Make sure the switch is in the "Learn" position. Place the rm-p311 and the remote you want to program in about 2 cm apart facing each other. Push the button you wish to program on the rm-p311. The indicator light should come on with a slight delay. Press and hold the button on the other remote until the indicator light goes out. Put the slider back to "User" mode and test it! For more info., go to sony's support site and search for the user manual for the STR-AV1070 receiver. It contains instructions for the remote.
    Jan 11, 2009 | Televison & Video
    Televison & Video Logo
    98 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
