Question about Toshiba 50H82 50" Rear Projection Television
Picture is not centered
My picture when in Gray Bar or Normal mode is not centered. It is about 1" to far to the right.
I cannot find anyway to adjust this.
Thanks
    Genius:
  • 1,694 Answers
Geometry adjustments are done in the servicer menu by
skilled technicians only.Adjustment service calls can cost
around 150.00.......T.
Posted on Oct 23, 2007
SOURCE:
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
I have a Sylvania 6427 17
It sounds that the width of the picture to your TV is more than normal. There are two reasons for this fault. If the width adjustment data value in its service menu mode has been misaligned or the output DC voltage from the main power regulator is more than normal. You can determine which among the condition stated above is now effected to your TV
Just look at the picture. If the width and height of the picture is seem to be more than normal, make sure that the power regualtor section circuit has the fault. If the dimension of the picture is affected to its width only, [excess than normal] the data value with service mode should be checked.
Also note the position of the picture. If the picture position has moved so much than normal, ether towards left in this case, you have to adjust the picture position. Anyway, it will be best to contact any experienced service technician, since, service mode entry and data adjustment are skilled work.
Jul 31, 2012 | Sylvania 6427GG 27" TV
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
I bought new monitor Compaq S1922a and picture stretched horizontal. I have HP intel with Vista. How to adjust VGA to make picture normal?
if the whole image is too long you can adjust it from tthe image driver ..it will be in the right side on the task bar near the programs that are opened all the time ..and named like the video card you are using and usually will display when hoovering the resolution in use..open the resolutions and choose one that fits best...and confirm ..
To adjust just the the picture from the desktop ..right click on the desktop..properties..and desktop...in there choose the desktop image ..or change image ..and you will have 3 possibilities for adjusting the picture to fit..center ...stretch..and tile.. see them one by one ...if non of the stile will make it visible in a normal way ..then you should change the picture,,and choose a wallpaper that it is in the same form and big enough to fit....
T change a picture on the wallpaper it is enough to right click on it when its opened ..and choose it to be set as wallpaper from the list of tasks...
May 31, 2010 | Computers & Internet
Gray bars
Hi, you can removed this bar by using the picture size function in you menu this is du to the signal
you receive in your tv;if your tv got a full hd signal
choose the 16:9 picture format the bar will disapear
if you dont have 16:9 signal that normal but you can choose full screen mode it should gone , that is 4:3
format extend it to ful screen mode.
good luck and have a nice day.
Mar 13, 2010 | Televison & Video
I have a ViewSonic N2635w LCD TV and the picture looks so stretched out width wise. I don't see anyway to fix the picture with the remote. How can I change the picture to look normal?
there should be something in the menu where you adjust things. seems as your in wide mode or zoom mode. should be something there to adjust the picture.
Jun 10, 2009 | ViewSonic N3735W 37 in. LCD TV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
