Question about Home Security
Bad eathernet card???
Monitor will display cameras but not picking up network throgh eathernet cable. may need new eathrenet card???????!!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Try a different ethernet cable first.
Posted on Aug 08, 2009
Whenever the monitor is turned on, it displays for about 3 seconds and then goes black. what to do? It is only about 3 yrs old
One of three things is the most likely culprit.
1. Onboard video card is either disabled or bad.
2. Cable is bad
3. Monitor is bad.
You can check the last 2 relativly easily by hooking the monitor and cable up to another computer to see if they function. if they don't then first try swapping out the cable (i say this first because its cheaper) then swap out the monitor.
To see if the video card is bad try hooking up a different monitor to the system. If the new monitor is not displaying anything then you most likely will need to put a new video card in the machine.
Apr 18, 2011 | Dell Dimension 2400 PC Desktop
The display has turned yellow.
Possibilities:
* bad connection of video-cable to monitor
* bad connection of video-cable to computer
* bad video-cable
* bad monitor -- connect to a different computer to see if it works, or displays the same symptom
* bad video-card -- connect a different monitor to see if the symptoms persist
It's probably time to responsibly-recycle that CRT, and spend $100 to buy a new 19-inch LCD monitor.
Oct 23, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
BUILT IN ORINOCO WIRELESS ADAPTER DON'T DISPLAY ANY NETWORKS
Maybe your internal antenna has come unplugged. Try opening the back plate and looking at the wireless card, usaually they have a black cable and white cable pressed onto two studs on the wireless card. carefully try to push the cables down firmly onto the card. NB this may void your waranty make sure battery is taken out before you start and not plugged into mains.
Mar 25, 2010 | MPC Computers TransPort GX3 Notebook
Monitor starts then goes off, no signal
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Sep 05, 2009 | HP w1907 LCD Monitor
I cannot review pictures on my Canon PowerShot A400
Yes, the first thing to try is a new memory card. They do go bad. As for the current card, hang onto it. You still may be able to retrieve the photos once you get back to your computer using retrieval software. See this link.
Jul 25, 2009 | Canon PowerShot A400 Digital Camera
Monitor says: no signal input check video cable Even though the computer is on and hooked up
if it says so....it indicates that the display card is gone bad. check with the display card...
or try inserting New Graphic card or PCI VGA card... works for sure....
Jun 23, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Goodmorning
make sure its not diabled if the eathernet card is disabled eather ing device manager or network connections it will not work try making sure both of these are enabled if they are make sure the cable is ok if that dosent help then it sounds like your eathernet card has gone bad
Mar 28, 2009 | Toshiba DOCSIS Cable PCX2200 (DAZ8817F-R)...
Biostar P4M80-M7A motherboard
You're board does not use an integrated graphics card.
Monitor does not have video display. There can only be four reasons why.
1. The monitor's video cable is not connected correctly at each end (Video card & Monitor) or cable is bad.
2. The monitor’s power cord is not plugged into a good power source or cable is bad.
3. The monitor may be bad.
4. * The AGP graphics card is either not seated correctly in its AGP slot, (remove/clean copper contacts with alcohol/allow to dry & reseat snuggly), or graphic's card is bad.
Monitor’s power cord can be switched with the PC's power cord.
The video cable & monitor can be swapped by borrowing from a friend.
(Just make sure their stuff is working first).
Never open the PC case without unplugging the power cord first.
Luck!
Mike
Apr 16, 2008 | Biostar P4M800-M7A Motherboard
MY PS3 WONT CONNECT ONLINE`
you need a crossover eathernet cord its diffrent then a regular eathernet cord
Aug 26, 2007 | Sony Playstation 3 (PS3) Console
Home Security Logo
57 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
