Question about Power Acoustik LT-980/2 Car Audio Amplifier
  • 631 Answers
Disconnect all of the speaker wires and signal cables from the amplifier.
If the amp still goes into protect when you power it up, the output transistors are likely shorted.
Posted on Oct 22, 2007
Nad av 716 protect
If your NAD amplifier is in protect mode with no speakers connected, it will be necessary to open it up and check for internal component failure.
Jan 05, 2015 | NAD Audio Players & Recorders
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
I have a spl fx2 1800 that i got from a guy for 40 bucks and it is frozen in the protect mode is there a way i can get it to come out of the protect mode with out sending it in to the shop
The most likely culprit when an amp goes into protection mode is the power wiring. Check your ground wire, it should be solidly connected to the vehicle chassis in a paint-free location. Then check the live power wire and make sure it has a good connection. If that doesn't work, download the user manual from That should help you to decode why the amp is in protect mode.
Mar 05, 2011 | SPL FX21800 Car Amp
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
Amp output is damaged and needs repaired. Protect mode cannot be deactivated. When amp is repaired and operating normally protect mode will not be displayed.
Aug 29, 2009 | Sony STR-DE597 Receiver
DUB 2502 Protection Mode help
The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Aug 07, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Why does my amp stay in protect mode?
The most common reason an amplifier goes into or remains in protect mode is shorted output transistors. To eliminate other possible reasons for it to go into protect, read the following page.
Troubleshooting - Amp in Protect Mode
Aug 03, 2008 | DHD NTX-2139 Car Audio Amplifier
LIghtning Audio B300.4 Protect Light
protect mode should be reset if the negative of your amp is disconnected then reconnectewd. if it doesnt help, move your ground to a different location. if THIS doesnt help, consider a repair or a new amplifier.
Jul 10, 2008 | Car Audio & Video
Amp in protect mode
Most time they go to protect there is something shorted in power supply. And at times it could be a bad amplifier transistor.
Dec 17, 2007 | Audio Players & Recorders
Amp going into protect mode
If you set the gain too high on the AMP, at loud volume levels some clipping or distortion of the output signal will occur. Most amps have a Circuit inside that detects this clipping or distortion and applies protection to prevent damage to the speakers and the amp. It would help to know if you are driving the speakers with a Line level output or using the speaker output from your deck. There are many things that can cause an amp to go into protect mode, and knowing a little more about your setup will help to solve the problem.
Nov 07, 2007 | Alpine PDX-4.100 Car Audio Amplifier
Power Acoustik LT-980/2 Car Audio Amplifier Logo
200 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
