Question about Tally T8106 Laser Printer
Replace belt CG
Tally printer T8106 printer reads replace belt CG
    Problem Solver:
  • 6 Answers
Set Belt CG The OPC belt cartridge needs replacement.
Replacing the Optical Photoconductor (OPC)
Belt Cartridge
Replace the OPC belt cartridge at least once every 12 months, or when
the control panel display indicates that replacement is necessary. The life
of the OPC belt cartridge for the T8106 is about 60,000 images (15,000
color pages), at a 5% toner coverage rate on letter-size paper.
1. Turn the power switch off.
2. Unlock the lever to open the front
cover. This releases the pressure on the
toner cartridges.
3. Unlock the lever to open the top cover
fully.
4. Pull the green OPC belt cartridge lock
levers up until they unlock.
5. Pull the used OPC belt cartridge
upward and out of the printer carefully
to avoid spilling toner.
6. Discard the used OPC belt cartridge
Caution! Do not touch or wipe off any powder that is on the OPC belt, nor expose
the OPC belt to light.
7. Remove the two shipping pins from the
new OPC belt cartridge.
8. Remove the protective sheet that covers
the photosensitive belt.
9. Slide the new OPC belt cartridge downward
into both green lock-lever guides
and into the printer carefully.
10. Push the green OPC belt cartridge lock
levers down until they lock.
11. Close the top and front covers carefully
until they both lock.
Posted on May 28, 2009
Error msg appear set belt cg dont know what to do.. am i have to replace the photodeveloper cg?
The error can either be caused by the OPC/OPC Marker assembly or the Main Motor assembly. Please follow the recommended troubleshooting steps:
  1. Power the printer off, remove and reseat the OPC unit, and power the machine back on. Print a test page. If error continues, proceed to step 2.
  2. Power the printer off and remove the OPC unit. Check the OPC Marker Sensor. If it is unsnapped or unplugged, reseat or replug it, and power the printer back on. Print a test page. If error continues, proceed to step 3.
  3. Remove the OPC unit and check it for scratches or defects. Also check the the markers on the OPC to make sure they are not damaged. Is the belt scratched or damaged? If the OPC is at or near the end of its life, OPC unit must be replaced. If the belt is in good condition, contact Lexmark technical support (if printer is under warranty) or your local authorized service provider for assistance.
Sep 30, 2010 | Lexmark C500n Laser Printer
Menu screen comes up with (Replace Belt CG)
The 'Replace Belt CG' message on the 8008 indicates the OPC Belt (Green Reflective Belt which is located in the top of the printer) has reached the end of its life and needs to be replaced to ensure the print quality is maintained.
If you are happy with the print quality you can clear the message via the control pannel on the printer, you will however need to remember you have cleared the error in the future when print quality is reduced you will then need to replace the OPC Belt.
The ‘Replace Belt CG’ message can be cleared in the following way;
With the printer OFFLINE hold down the MENU button for 2-3 seconds until the display changes UTILITY MENU and then release the MENU button
Press the MENU button once more
The display will read "Utility Menu Clear Belt CG", press the MENU button once more
The display will change to "Clear Belt CG Not Execute" by pressing MEDIA/> key again the display will change to "Execute"
Press the MENU/ENTER key again after 10 seconds the display will change to "Completed Clear belt CG"
Press the UP ARROW button twice to exit the Utility Menu
Press the ONLINE button to return the printer to the ONLINE state
The ‘Replace Belt CG’ message will now be cleared.
Jan 28, 2010 | TallyGenicom 8008 Laser Printer
What does Replace Belt CG mean?
When the Replace Belt CG message appears, the photodeveloper cartridge has been exhausted and will need to be
replaced. Order Lexmark part number C500X26G.After a new photodeveloper cartridge is installed, reset the
photodeveloper count.
1 Make sure the printer is on and the Ready message appears.
2 Press .
4 Press and hold for 3 seconds until you see Utility Menu, and then press .
5 Press until you see Clear Belt CG, and then press .
6 Press until you see Execute, and then press .The photodeveloper belt count is now reset.
7 Press to return to Ready.
Jan 12, 2010 | Lexmark C500n Laser Printer
My Tally T6218 gives the following error message shuttle fault
may shuttle belt is lose or it is not in proper place. check the shuttle belt and clean the shuttel sensor , your problem will be solve.
Nov 30, 2008 | Tally T6218 Matrix Printer
Tally T8106
The T816 can be used with Vista and XP over a Ethernet connection....You will not however be able to 'discover' the printer on the network.You need to set an IP Address in the printer or if the printer has been allocated a DHCP address you would need to find out what address has been allocated.
Once you know the IP Address you would need to install the printer on a PC/Server then share it to other users to be able to 'see the pritner on the network'
Once the pritner driver has been installed you can create a network port in the pritner driver to print to the IP Address of the pritner in the follwing way (on XP, Vista will be simmilar)
· Open PRINTERS folder
· Right Click on the printer driver for the T8106
· Select PROPERTIES from pop up menu
· Click on the PORTS tab
· Click on the ADD PORT button
· Highlight STANDARD TCP/IP PORT
· Click on NEW PORT
· This should open the TCP/IP Printer Port Wizard, work through this entering the IP Address and Port Name. Windows may try to detect the port configuration required.
· If the type of port is not automatically detected click on the CUSTOM radio button.
· Click on the SETTINGS button
· Change the PROTOCOL to LPR
· Under LRP SETTINGS enter the Queue Name as PASS
· Click OK.
· Click NEXT and then FINISH to finish the TCP/IP ports wizard.
Oct 27, 2008 | Tally T8106 Laser Printer
Is the massage replace the cg belt the same as the ocp message as i can't see any damage to them at all.
You are correct the 'Belt CG' is the OPC belt cartrige. The mesage advising this item needs to be replaced comes up as the result of a page counter in the printer. The mesage comes up as a result of the page counter exceeding the maximum number of pages expected from the OPC, ensuring reliable print qulaity.
The message does not indicate the OPC Belt is damage, it has reached the end of its designed life.
Aug 26, 2008 | TallyGenicom 8008 Laser Printer
Tally Genicom 8008
The Set Belt CG message on the 8008 indicates the printer is not detecting the OPC belt (the green reflective belt located in the top of the printer)
Try removing the Belt Cartridge and relocate this in the pritner, if this fails to fix the problem remove the Belt Cartridge from the printer then look down one side of the belt- (I think the left side of the belt), for black squares (I think there are two) the printer uses these to detect the Belt Cartridge is rotating. Check for damage to the Belt in this area. If the printer does not detect the belt as rotating it will indicate this error.
If the Belt Cartridge looks ok, remove the Belt Cartridge from the printer then look down the hole left in the printer when the belt cartridge is removed. Look for any obstuctions, also look at the black belt which is towards the back of the printer when you look in the top ( the transfer belt, I think) Look to see if there is any damage to this it may cause the Set Belt CG message.
Apr 02, 2008 | TallyGenicom 8008 Laser Printer
Tally T8106
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  • Power the printer on while holding down MENU/ENTER key
  • Release the key when the display shows "Utility Menu Clear FC. Roll"
  • If you have replaced the FC Roller then select this option by pressing MENU/ENTER key, if you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  • When one of these options is selected by pressing MENU/ENTER key, the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute" by pressing MENU/ENTER key again the display will change to "Execute"
  • Press the MENU/ENTER key again after 10 seconds the display will change to "Completed Clear FC. Roll / belt CG"
  • Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jan 28, 2008 | Tally T8106 Laser Printer
Error Message ('replace belt CG')
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jul 12, 2007 | Tally T8006 Laser Printer
Tally T8106 Laser Printer Logo
381 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
