Question about Garland H283 Gas Kitchen Range
I have a 1950's Clare Jewel Gas Range I would like to clean it
I would like to clean the drip plate that is under the burners
2 Suggested Answers
SOURCE: gas meter was changed upon relighting,top burners pilots are on but oven not
under each (the) oven behind a panel, is a red button it may be a different color from time. this has to be pushed and held while the pilot light under the oven floor is lit with a match. it has to be held to allow enough heat to activate the thermocouple, which will keep the pilot on. if this does not work there may be an additional problem
Posted on Jan 23, 2009
How do i open the top to clean under the burners
Normally it's easy. Just lift the range top from the front andtheir should be a lever to pop up and support the range top while you clean. :)
Dec 02, 2015 | Maytag Kitchen Ranges
HOW TO TAKE OFF THE TOP BLACK PLATE ON MY FRIGADAIRE RANGE PLGS389ECC
Good Morning Bob,
I see that you are having trouble with your burners and are looking for instructions on how to take off the black plate on your Frigidaire range, model# PLGS389ECC. First, I do suggest, that for these kind of repairs, you contact a local authorized technician. Second, I don't necessarily have instructions on how to take that plate off, but I have listed below, a link that will give you a parts breakdown of your range.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995457891.pdf
-Best Regards-
WP
Mar 31, 2014 | Frigidaire Ovens
Thermador has had sudden no gas to whole unit
They may have accidentally turned off a little gas cock which is cunningly hidden on the front panel can\'t remember if it\'s top or bottom, it isolates the gas to the main control valve.
Mar 20, 2014 | capital Precision GCR484G 48" Pro-Style...
Is there a cleaning manual for my 6 burner/griddle viking range?
I have a product that I use to clean my burners and griddle with, it is made by ECOLAB and is called Greasecutter Plus. It doesn't hurt the range but it makes it look brand new, even my griddle comes completely clean. You just spray it on then let it sit for a bit then it wipes clean.
Apr 18, 2010 | Viking 48" 6 Burner, Grill Professional...
Broiler works but oven does not ge xl 44 model JJBP24BEA2WH serial LV201917P Is this worth fixing?
Hello-  Yes if it's the igniter for the oven burner. The lower burner may light, but if igniter is bad, gas flow will not increase, causing under-temp condition. The part is available for 40-75$, and is fairly easy to install. Part is accessed by removing drip pan at bottom of oven. Gas ranges last longer than electric if the self-clean 'function' is avoided. Go ahead and fix it!  Let me know if this info helps-- have more if needed.   Thanks-  Ed
Mar 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Top right burner on hotpoint gas range doesn't light
there is a spark ignition in the middle between the front and back burners....one for the left side and one on the right side. When it was cleaned i bet that the spark ignitor was slightly bent towards the front burner...now the gap is too big to fire the rear burner...the ignitor is very similar as the spark made in those push down lighters. so its safe to play around and adjust them as needed to make them work...Go ahead and take it apart and tinker with adjusting it...until you get both front and rear burners running again the way it was before.( peek at the otherside as a reference and try to make it match)
I hope this helps you out a little bit 8-)
Jun 06, 2009 | Hotpoint RGB745 Gas Kitchen Range
Gas meter was changed upon relighting,top burners pilots are on but oven not
Apr 10, 2008 | Garland H283 Gas Kitchen Range
Low gas Flame
check the vent plug on the regulator.
Dec 24, 2007 | Rangemaster 110 (Gas) Kitchen Range
Garland H283 Gas Kitchen Range Logo
445 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
joneable
Level 1 Expert
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
