Question about Kenmore 30 in. 42701 / 42702 / 42709 Electric Cooktop
All top elements quit working on my Kenmore glass top range.The clock and oven light still work.
  • bh99603 May 28, 2009
    It's a glass top range so there are no element receptacles to check
    Novelist:
  • 151 Answers
They have a thermal overload resistor in the burner itself and they have a propensity to burn out, or it could be the infinite switch. You will have to check resistance across the leads that correspond to each pinout. You can find this out by backtracing the wire to each terminal on the block. Replacement of either part is the only option, there are no safe alternatives to repair them. Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
get the selector switch and oven control checked by multimeter Oven temp problems: Temperature is too low possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
Temperature is too high in the oven possible trouble makers, oven temp control, oven relay ( if used ), oven probe clips, oven temp sensor, shorted wire.
Checking a surface switch : Many infinite surface switches physically look different, but they operate almost all the same way.
Test with an ohm meter. . . .Unplug the range.  Turn the switch to a high on position, you should be able to hear it "click" into the high position. Remove the wires from the infinite switch. Be certain you know how to replace the wires. Check across from L1 to H1, L2 to H2, and P to H1. If there is not continuity across all these points, the switch is defective. Sample internal picture here.
Test with an voltmeter. . . . . Unplug the range. Remove access covers to get to the switch. Plug the range back in. With voltmeter set to read on the 240V scale, read across L1 & L2. ( no power there, check fuses or wiring ) There should be 240 volts present here. Turn the switch on to a high setting. Read voltage across H1 & H2. There should be 240V present here. If you don't read 240V here, replace the switch. Sample internal picture here.
if you are not familiar with checking get it checked by a repair technician.its not a major problem.you can get the parts at
www.repairclinic.com
its worth getting replaced as the switches are mostly the culprit.
thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 28, 2009
    Brigadier General:
  • 3,917 Answers
Ok if the wire arced on something then the breaker either half tripped and is not sending the correct power or something is shorted the control maybe. Go to the breaker box and flip the breaker on and off then try!! or Many times a surface burner element can burn out. Look for obvious signs such as breaks or bubbles on the surface, loose or corroded wire connections, and test the elements for continuity. Sometimes the element receptacle or the element ends can get burned out or loose, causing a poor connection or no connection. If this is happening, you should turn the power supply off, and remove the element to inspect the plugs and receptacle. If you see burn marks or corrosion, it's time to replace the bad part. You can also check the terminal ends by lifting them out and looking to see if they got bent and have lost connection. Straighten the ends and re-seat the element if it had bent ends.
Thank You
My elements are off but the red light is still on?
Red light will stay on until burner temperature is down to a safe level.
Oct 02, 2016 | Frigidaire Stove/Oven/Range Black Glass...
Where are the fuses on a fridgidare range,glass top,everything works except thesettings for my stove doesnt light up
Thank you for your post, friend!
Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
Mar 10, 2015 | Frigidaire Stove/Oven/Range Black Glass...
My stove top works but oven and broiler will not heat
Good Afternoon friend, thanks for your post!
I see that your oven and broiler will not work on your Frigidaire range. It could be possible that your elements are bad or the thermostat may have shorted. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue you may need to have a professional technician come out to pinpoint the issue within your range. Best of luck! -Matt
Feb 16, 2015 | Frigidaire Stove / Oven / Range Glass...
We had a power outage and now the oven will not come on the rest of the stove works inckuding the clock the preheat and oven lights come on but the oven does not heat up, we have tried turning off the
My guess is the element in the back of the oven took that moment to die. You will have to get an appliance engineer or good DIY electrician to check the supply to the element to be sure. While you have it out you can write down the serial numbers etc off the label on the back. You will need them to purchase a new element. Just go online to an appliance spares specialist.
Dec 29, 2014 | Kenmore White Electric Stove
I replaced what I thought was a bad 9" heating element on my Kenmore glass top stove and the new element still does not work or even attempt to come on. what should I do next?
Did you check if electricity was coming to the element. Try putting a volt meter on the two wires and turn it on see if you get anything...could be a bad switch
Sep 15, 2014 | Kenmore Frigidaire Glass Cook Top...
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kenmore 30 in. 42701 / 42702 / 42709 Electric Cooktop Logo
298 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
