Question about Panasonic NN-S254BF Microwave Oven
Panasonic microwave s254bf stopped working
It went totally black one day and then the next STARTED TO WORK FOR A WHILE AND NOW IS TOTALLY DEAD.  Happened when no one was using it.
  • Panasonic Master
  • 9,098 Answers
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to
open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-S254BF Microwave Oven
Microwave (Panasonic NN-S254BF) starts, runs 2-3 seconds, and then shuts off. I have checked the door latch switches, and they are all working like they are supposed to. Whats wrong?
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Jun 06, 2010 | Panasonic NN-S254BF Microwave Oven
Panasonic NN-S254BF microwave oven runs for 2-3 seconds and then shuts off'
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
May 31, 2010 | Panasonic NN-S254BF Microwave Oven
NO POWER
Most likely have blown a fuse , get behind the touchpad to ohm the fuse out , replace if blown , if continues to blow check componets for shorts , there will likely be signs of burnt parts.
Phil
Apr 14, 2009 | Panasonic NN-S254BF Microwave Oven
Panasonic microwave
the child lock feature is activated.
if you can look at your manual, it would be stated there how to activate and deactivate your child lock option.
tnx 4 using fixya
drcool
Sep 01, 2008 | Panasonic NN-S254BF Microwave Oven
Stops after 3 seconds - Panasonic NN-S252BF
may be magnetron spoiled or high voltage section problem,please check circuit andreplace damage parts...
Aug 14, 2008 | Panasonic NN-S254BF Microwave Oven
Touch pad went dead
your Display board will need to be replaced
Jan 23, 2008 | Panasonic NN-S254BF Microwave Oven
Faulty microwave oven
So it's dead? (No lights, no beeps when you press a key?)
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
But - this model uses and inverter. Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
But if you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 08, 2007 | Panasonic NN-S254BF Microwave Oven
Dead microwave
check mains fuse and check control circuit and magnetron. and diodes capacitor  high voltage related circuit. small part also gone microwaveoven doesnot works, first check oven and conform which part was spoiled, after that this is worth or not old ovens good compaare to new ones...
Oct 25, 2007 | Panasonic NN-T888S Convection/Microwave...
Panasonic NN-S254BF Microwave Oven Logo
1,157 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
