Question about Brother MFC-3240C All-In-One InkJet Printer
Brother MFC 3240C error unable to change appeared and can't fix
I went through the trobleshooting instructions in the manual but the same message appears . There isn't anything stuck in the printer and it just seems to be locked in this error mode....please assist!
  • 3 more comments
  • klajwalker May 29, 2009
    Error message "unable to change" appears in window of printer and it also says see manual for troubleshooting and routine maintenance. I did go to the manual and did what they suggested but the machine is still displaying the same error message and I can't seem to get it to clear out of that mode.
  • klajwalker May 30, 2009
    everything appears to be where it should and we still get the same error message
  • klajwalker Jun 01, 2009
    this didn't solve the problem
    that's what I was afraid of and it's just better off to get a new printer...thanks for the help
  • adi May 11, 2010
    it would help if you told us what the problem is.
  • 526 Answers
Check to see if the encoder strip is outside of the printhead assembly.
you will need to slide the printhead al the way to the left and see if the encoder strip is in the printhead groove.
Posted on May 30, 2009
  • 1 more comment
  • adi May 31, 2009
    check to see if there is some type of paper or foreign object in the far left and far right where the printhead moves. you might need to shine a flashlight in there.
  • adi Jun 01, 2009
    then your flushing box and pads will need to be replaced.
    The waste pads in your printer are full of ink, and you have to do its end of life maintenance.
    There are two parts that need replacing, parts and labor will be approx. $85- $135 depending where you go.
    thanks
  • adi Jun 01, 2009
    if you can rate me, I'd appreciate it.
Message states: Unable to clean. See
From Brother:
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000500/000065/faq000565_000.html?reg=eu&c=eu_ot&lang=en&prod=fax1840c_all
I have seen this too when the waste station is full. If this is the problem, it is likely time for a new machine or a reasonable repair bill.
Jun 08, 2010 | Brother MFC-3240C All-In-One InkJet...
Unable to init.after period of none use
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 23, 2009 | Brother MFC-3240C All-In-One InkJet...
Machine Error 51
More than likely you have a bad printhead, if its under warranty brother will pay to have it fixed, otherwise just play baseball with it and buy another one
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
Brothers error message 50
Check for remaining ( small peace) jammed paper inside.
Jan 23, 2009 | Brother MFC-3240C All-In-One InkJet...
Can not initiate
... Are you sure about the exact error message?
This link seems to have a related explanation for something that sounds kinda similar
If not, from http://www.brother-usa.com , you can find your printer's support page and then e-mail support. Nothing involving the word "initiate" appears in the user manual; I looked.
Jan 19, 2009 | Brother MFC-3240C All-In-One InkJet...
Change LCD language to English on Brother MFC-3240C
Gud Day!
Power on your printer. Press the menu of your printer then sect the arrow down or up to select the language menu. press ok if u have seen language then go to option select from german to english.
Please rate the solution after you have tried it so that I can assess you more on this problem.
Jonags
Dec 11, 2008 | Brother MFC-3240C All-In-One InkJet...
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Jul 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Printing after being on same phone line as printer/fax
This link will open the Users Manual, but you will need a PDF viewer such as Adobe Reader or Foxit Reader in order to open it.
Go to page 12-4 in Chapter 12, Troubleshooting and routine maintenance. Follow the actions recommended for the Unable to clean error message (and the four other Unable to... error messages).
Jul 04, 2008 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-3240C All-In-One InkJet Printer Logo
336 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
