Question about HP Computers & Internet
Mouse not acting
Bluetooth mouse rnot acting even the usb key is recognised by the system
    Master:
  • 409 Answers
Hev you checked the batteries?
Posted on May 28, 2009
My mouse wont get recognized
Have you tried to use the mouse in another computer to determine that the mouse if fully working. There are many reasons why it could be non-recognised. Has it ever worked on your system? Is it new and just a faulty mouse. It may be you could just take it back to the shop for a replacement one. Do other devices work in the same USB port. Some times my computer just stops recognising my USB keyboard yet it has been working for months. I found that it seems to be the USB port where the problem is. So not I just switch my mouse and Keyboard usb connectors around and it starts to recognise both again. I can not figure out why it stops. As another device is recognised suggesting the port is not faulty.
Nov 01, 2013 | Computers & Internet
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
I cant get my mouse to connect to the computrer, I have the mouse and the batteries are inside but is there supposed to be a reciever with it?
If you are talking about wireless mouse than definitely yes , it should have a usb device which will go to your PC or Laptop usb port so that your mouse can communicate with it and work.
If you are using a laptop which has a inbuilt Bluetooth and even your mouse is also a Bluetooth mouse, In this case you have to you Bluetooth device setting application and pair your mouse with your Bluetooth devices.
All the Best.
Jul 10, 2011 | Logitech Cordless Mouse
I am unable to get my mouse to work on my hp pavilion. I have tried a new mouse , both cordless and wired, nothing happens. I'v tried many suggestions. Could be in the processor? The desktops comes up.
You need to first check the settings of mouse in the control panel and try to plug in the mouse again ,,, and check if rnot try to reinstall the windows , it might be because the driver you have on the system has gone corroupt
Oct 20, 2010 | HP Pavilion a735w (PL308AAR) PC Desktop
Just got the bluetooth keyboard and mouse w/ no manual. how do i set it up?m/s bluetooth keyboard WBR0295 X08-92475 product ID 69418-545-205333 5-00321 and m/s bluetooth mouse p/n X08 - 87659...
Hi.
Before starting, make sure the keyboard and mouse are ON and with batteries.
Whit the PC already ON:
* The first step is to plug in the USB Bluetooth adaptor.
* Once the Bluetooth adaptor is inserted, allow Windows to install the drivers.
* Once Windows gives it the OK, the USB dongle should have a light or even a button. (If you don’t see a button the "yellow" light is the button).
* Press the USB dongle button....this will tell the dongle to start looking for a Keyboard or mouse.
* On the underside of the mouse (and keyboard) should be a a small button.
* Press the button(s) for ~5 seconds, then release.. this tells teh keyboard (or mouse) to look for a dongle.
This should show a connection between the dongle and the keyboard (or mouse).
Or
With the PC Off:
* Just connect the dongle
* Do the button sequence as described above, unit the dongle light goes “solid” again.
* Start the PC and keyboard and mouse should work perfectly.
Cheers,
Ed
Oct 24, 2009 | Microsoft Windows XP Professional
Aspire 5100 it does not recognise the keyboard
borrow a friends keyboard and mouse...log on to your computer and go to system restore and go back to a time when you knew you could use them and restore to that date
sometimes funny updates cause external hardwares to act up
Brentwood IT
Sep 25, 2009 | Acer (918EA10I10) Motherboard
I have a cordless keyboard & mouse my desktop will not recognise it
Use a USB keyboard and mouse first. Go to the Control Panel and look for the Bluetooth Devices icon. Delete all BT devices from it. Turn on the bluetooth keyboard and make sure that you see a blue light. Then Add a device from the Bluetooth properties. Click "My device is ready to be found" then hit Next. Once it detects your keyboard just choose "Do not use a passkey". It should be able to detect your BT keyboard. Do the same thing with your mouse.
Please rate this if it helped.
Thanks, ArnWuLF
Dec 07, 2008 | Computers & Internet
Wireless mouse doesn't work
This problem was happening on my system but i managed to fix it easily! What has happened is your itouch software has become corrupt so it will only recognise your keyboard thus the usb connection. You will need to download/install off disc onto your computer again but do NOT go to uninstall program manager on windows as it will not appear there because even though you can access the itouch configuration panel, the database is corrupt and the administrative system will not recognise this. Just download/install via disc and it will just install with no alerts unlike most programs which will recognise the program is already installed onto the system. Once the setup is 92% it will freeze for a second then the found new hardware window will appear on screen go through that process and your mouse is back to normal and your keyboard will work via itouch software.
(Please note that this will only work on windows)
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
USB drive not recognizing
check your usb drive on some others system , if the problem is the same , then its the fault of your device replace it
Jul 16, 2008 | Lenovo 3000 Y410 Laptop
Bluetooth
usally laptops have bluetooth not desktops ,,,,bluetooth is not the same as wireless ,,i know they work similar bluetooth is for short distance...when u set a blue tooth mouse up u must have bluetooth usb plugged into ur computer ...that usb adapter will act as your mouse connection ......
Dec 09, 2007 | Microsoft Wireless Optical Mouse
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
