Question about HP PhotoSmart 1218 InkJet Printer
HP G85xi printer - No color output
Dear Sir,
No color output
Try test pages - No color output.
Try Cartriage load and contact looks ok.
Eugene
  • 4,889 Answers
> First thing to try is a cleaning and maintenance cycle. There are also
> rare instances of cartridges being defective, it may have one of those.
An uninstall and reinstall of the printer may also help
Posted on Oct 21, 2007
"Check Color Cartridge" displays even after replacement of cartridge -though I don't think original cartridge was empty- and stops printer from printing. The new cartridge is installed properly, and...
  1. First, check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges.
  2. Second, make sure your paper is not causing the problem. Paper that does not accept ink well can cause your images to smear or bleed. Plain paper is not the best choice for high-density graphics. Click here to see how to pick the best paper for your project .
  3. If the paper is not the problem and you are using genuine HP cartridges, print a clean test to see if the printer and cartridges are functioning properly. Load the printer with clean, plain, white paper and print a clean test page. To see how to print a clean test page, see your printer's User's Guide , or see HP Deskjet Printers - How To Print Internal Tests , or HP All-in-One Product Family - Printing Self-Test Reports .
  4. Evaluate the clean test page. Different printers produce different pages, but you should recognize elements from the examples below on your test page. In general, cartridge and printer problems are indicated by streaks, missing colors, or wrong colors.
    • Examples from a good printer and cartridges (your test page may not look exactly like this): Figure 1: Solid colors that match color dots on cartridge labelc00059224.gif Figure 2: Pattern unbroken, or broken in only a few placesc00059225.gif
      c00059227.gif If your test page looks more like the good examples above than the bad examples shown in the next two sections below, the printer and cartridges are probably not causing the problem. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - streaked or broken bars or lines Figure 3: Fading, missing, or streaked bar - low-ink or empty cartridge, clogged nozzles, or electrical problemsc00059228.gif
      Figure 4: Color completely missing (magenta bar missing below)c00290898.gif Figure 5: Lines broken randomly - clogged nozzlesc00059231.gif
      Figure 6: Lines broken in pattern - dirty contacts or other electrical problemsc00059232.gif
      Figure 7: Color completely missing (magenta pattern missing below)c00290899.gif If your test page looks like these examples, you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - colors do not match the color dots on the cartridge label (Note: do not compare the test page colors to the colors of the examples on this web page. Your monitor may not display the colors properly). c00059234.gif c00059235.gif If your test page looks like these examples, you probably have a cartridge in which the inks have mixed. Click here to continue troubleshooting .
Oct 26, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
HP G85xi remove and check color cartridge message
Hi you can remove your Printer cartage and look see
ink points (dots) you can erase ink point and reattach your cartage your printer its Ready to use.
Jul 06, 2017 | HP OfficeJet G85 All-In-One InkJet Printer
I put in new color and black cartridges a couple of days ago and was able to print okay. Now I keep getting ''Remove and Check Black Cartridge'' prompt. I've taken out Black Cartridge, turned off printer,...
hope you put back both cartridges before trying again..try wiping the tip of the black cartridge before replacing it..then activate the head cleaning process..
Oct 03, 2017 | HP G85xi All-Color InkJet Printer
HP G85XI Printer
Replace both ink carts with GENUINE HP ink carts.
Mar 09, 2009 | HP G85xi All-Color InkJet Printer
Hp G85xi ink jet printer. Keep getting the
Possible your printer is equiped with by optical sensor of the determination to density of the paper. If he was littered by dust, that you it is necessary to clean his(its) compressed by air.
Mar 06, 2009 | HP G85xi All-Color InkJet Printer
No Macbook Driver for HP G85xi
Do an internet search on gimp print, there are 3rd part sowtware solutions to this.
Dec 20, 2008 | HP G85xi All-Color InkJet Printer
No ink on page
Clean the contact in the housing area and on the ink cartriage. If that does not work buy a new cartriage. The ink probably dried up in the nozzles. You can place the ink cartriage on a wet paper towel water or alcohal and press the cartriage into the towel. If you see no ing replace.
Jun 11, 2008 | Office Equipment & Supplies
Cord needed to work with our new Dell computer
i have a g85xi my self and you will need to use a cable to connect from the g85 to your usb port on the dell i have a hp wich is basicly the same one end of the cable be square and the other end is a usb end
Jun 01, 2008 | HP G85xi All-Color InkJet Printer
HP PhotoSmart 1218 InkJet Printer Logo
37 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
