Question about Hannspree HANNS·G HC174DP 17 inch LCD Monitor
Blank part on my monitor
I have a Hanns-G HC174D monitor and as said, it is now displaying a 2 inch black line down the right hand side of the screen, this has only started in the last two days...
  • 31 Answers
This sounds like a claim. Give it back to your seller.
Posted on May 28, 2009
Laptop is connected to the external LCD monitor, the monitor is on but screen is blank
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor AND external monitor source
3) External monitor source ONLY
Hold the Fn key down, and tap once on the F5 key.
Hot key through until you find the setting you want.
Release the Fn key
Regards,
joecoolvette
Apr 16, 2013 | Toshiba TECRA M9 Notebook
Blue vertical line appears down left hand side of screen. I thought "dead pixels" but sometimes the line is gone and the screen is back to normal. Any ideas would be appreciated. Thanks, John.
It will be one of two things, the video cable from the computer to the monitor, if you can detach both ends, sub another cable, failing that the problem lies in the main board that is attached to the LCD panel and where the video is processed and viewed on the display. Unfortunately to repair this type of problem will exceed the amount for a new monitor.
Feb 17, 2011 | Hannspree HANNS?G HU196D Monitor
Have a green rectangle about 2 inches by 5 inches in center of screen with yellow letters that say, input signal mout of range. It is A hanns g hg281d monitor
Restart your computer,
and keep hitting the F8 key until a "start-up" menu
(white text over a black background) is displayed.
Choose "Safe Mode" and let Windows start.
Reset the screen-resolution to 800-by-600, and 60 Hertz refresh-rate.
Restart your computer, normally,
and then "tweak" the screen-resolution and refresh-rates that are "optimal" for your monitor.
Aug 09, 2010 | Computers & Internet
POWER LED ON BUT NO IMAGEN
I HAVE A DELL MONOTOR WITH, TODAY I TURNED IT ON AND IT HAS A 2 INCH YELLOW LINE GOING VERTICAL ON THE LEFT SIDE OF THE SCREEN ...WHAT CAN I DO TO POSSABLY FIX THIS ISSUE?
Jan 31, 2010 | Hanns.G Corporation HW173D Monitor
Gateway monitor problem
Does this monitor has a reset to factory specs on the menu? If so then select it.
Jan 05, 2009 | Gateway FPD1760 17" LCD Monitor
Flashing lines down the right hand side of my monitor
It could be two things.
1. The graphics card is failing.
2. The monitor is exhibiting a defect.
If you have graphics card plugged into your computer, try disconnecting the card and hook your monitor into the built in video port and see if the issue goes away. If it does, then the video card may be failing. If you dont have a seperate video card, then the monitor might be having issues itself. Of course Onboard video can display this behavior too although I have not personally seen it.
Aug 15, 2008 | Dell E228WFP LCD Monitor
Looks like a crack in the display
such issues have occured in the Past, Please Check if the Crack appears in the BIOS mode.Safemode also Try another Monitor to find out if it is not the wall paper because if it is then the Crack will appear in the other Displa too...
Jul 17, 2008 | Computers & Internet
Black line down right side of the monitor (Acer AL1914)
I have a toshiba laptop and my two year old son has just pressed all the buttons when i was out the room and i now have one inch black margins on either side of my screen that i just cannot get rid of......any ideas would be much appreciated!!!!!!
Jul 14, 2008 | Zonet KVM3002 2-port KVM Switch
1inch black line down right hand of screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 15, 2008 | Computers & Internet
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Hannspree HANNS·G HC174DP  17 inch LCD Monitor Logo
197 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
