AC unit outside turns on but no air blows through the vents
When I turn on my AC, the unit outside turns on but no air blows through the vents. If I switch it to the heater air then blows out of the vents. My A/C turns on but never cools the house.
  • Mike Sep 01, 2012
    sounds like a stuck relay..and heat strips could be on during the cooling cycle...is you fan running when you say it don't blow air?? sounds like a relay..check it let me know.
    President:
  • 1,902 Answers
The first problem sounds like the wiring is wrong up at the heating unit not turning on the blower fan in the heater when you call for cooling. Most typical is either something has chewed the wires or the wires have been stripped b something else. The AC not cooling your house can be either it is low on freon or the system is to small for your house. Also check your filter and make sure that it is not blocked and everything is clean with the filter
Posted on May 28, 2009
  • Mike Sep 01, 2012
    yep could be that to
3 Suggested Answers
  • 400 Answers
SOURCE: AC unit outside turns on but no air blows through the vents
Your indoor unit pc board is bad, replace it.
Posted on May 08, 2009
  • 358 Answers
SOURCE: AC unit outside blowing out cold air, vents
If you have a heat pump probably there's a wrong connectionin the thermostat, but if is not a heat pump ,the compresor is not working or the unit leaked all the refrigerant.
Posted on Aug 30, 2009
Testimonial: "thank you, we have had a problem in the past with refrigerant leaking, was supposed to be fixed"
Why when ac is turned on motor is off and nothing blowing from vents
Is the outside unit running? If it is you either have a blower relay out or your inside fan motor is bad. If the outside is not running you turn on the fan on the thermostat to ON not auto to see if the fan motor comes on.
Jul 15, 2014 | Heating & Cooling
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
AC on but nothing coming through vents
the therostats adjust a damper to open air flow . it could be a damper motor problem. or it could be the ajustment of the tstats. turn the up stairs up then go to down stairs turn it down. then see if the air is flowing. i hop this helps
Apr 15, 2010 | Ruud UAKA037 Air Conditioner
My air condition inside unit seems to be freezing up and the air stops blowing through the vents after I turn it off it sounds like ice melting. after a few hours I can turn it back on ,it will blow throuh...
When evaporator is full of ice, check the following;
Note: You may actually need the service of a qualified technician. Proper tools are needed also.
  1. Clogged filter/drier. Clean or replace filter/drier. You have to discharge the refrigerant first then recharge after replacement or cleaning. The system must be evacuated of moisture, dirt,metal chips or any particles that can cause clogging on the capillary tube.
  2. Evaporator fan. The the fan if can be turned manually. If not, realign and lubricate. It should turn freely..Otherwise it must be replaced.
  3. Refrigerant: Check the refrigerant using a gauge manifold. Repair leaks and recharge refrigerant .
Sep 07, 2009 | Goodman CKL60AR60 Air Conditioner
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
May 08, 2009 | Heating & Cooling
My Carrier AC fan will not turn, only blows out warm air.
Breaker has popped either at breaker box or at the safety shut off switch. Fuses are blown or the sending unit has popped.
Apr 30, 2009 | Carrier BCA101R Air Conditioner
There is no air blowing out the vents on the dash board when i turn the ac on
you have a bad control unit, the thing you use to switch from one thing to the other, it needs to be replaced.
Oct 19, 2008 | 1998 Oldsmobile Regency
Heating & Cooling Logo
848 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
