hi sometimes the ringtones from mthe card will go to the phone memory but this is not the problem.
the ring tones are small in size.
each program have to be set card memory or phone memory.
the picture or video is the biggest memory "eating"
i think this is your broblem you have to move all your picture and videos to the card from the phone and than set the phone to use the card for picture and video.
Did you save music files on phone memory? If yes , it is time to move it to your memory card. Also check for other big files that still keep in phone memory. If able , just move also your theme files to memory card. Move / delete also old messages files, games (if any), etc in phone memory.
Like computer, your phone need enough space for caching.
The phone's internal memory and memory card may be running out of space. Try to delete unnecessary files and free some memory space. Go to Menu>Tools>File Manager. Select the folder or file you want to delete and scroll left or right to switch from the phone's internal memory to the memory card.
Format the memory card and the phone's internal memory if the problem is not resolved above. But it will erase all saved data on both memory.
Memory Card Formatting Procedure
Go to MENU > TOOLS > MEMORY.
On the memory card menu press OPTIONS.
Scroll to Format memory card.
Press Select.
Select Yes
Once the formatting is complete, remove the memory card.
Phone Memory Formatting Procedure
On your phone dial *#7370#.
Press Yes then enter your phone lock code. Default code is 12345.
Formatting is complete when the phone restarts. Insert the memory card and format it again.
Solution 1: Set to save the files into SD card rather than into Phone memory. For example, set song folder and picture folder to a location on memory card. Refer to the phone manual for detailed steps.
Solution 2: use a computer and card reader to manually store songs into SD card. Then set the phone to folder into sd card to get the songs. Clear phone memory afterward.
In SE Z550i there is no option to move text messages from phone memory to external memory card. The phone comes with 20MBs of onboard memory which is shared by phone's functionalities such as calnder, to do lists, phonebook/contacts, messaging, installed games and applications, etc.
The problem that you've mentioned above can occur when you store/install other files such .mp3, photos, games and applications, etc. on your phone's memory instead of the external memory stick. Please check if there are any mp3s, photos, etc. stored on your phone memory and move them to the memory card. In future, try to keep the phone memory as free as possible from mp3s, photos, etc. and please do not install too much of games and applications in the phone memory, instead install them on the external memory. If you have already installed many games and applications in your phone please check if they are installed on your phone memory and if they are please move them to the memory card.
Have a great day!
try again format ur phone,but b4 that,put out ur memory card.after format ur phone,format ur memory card on pc by using card reader.after both format complete,put ur memory in phone,format ur memory card again in phone.ok.try this 1st.send feedback to me.
