Question about Philips Magnavox 20MT133S 20" TV
Will not go to wizard set up, says weak signal
Remote doesn, work either
  • 822 Answers
Check battery if properly working. if not change your remote. carbon is circuit is damaged.
Posted on May 28, 2009
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Oct 20, 2012 | Home Security
Weak signal from remote or submarine problem
The infrared dignal emitting diode in the remote control might gone weak. It can be replaced. Seek tech support.
Jun 01, 2012 | Televison & Video
Signal interruptions on digital TV set
Weak signal is a weak signal, so not sure what if anything you can do. Buy a satellite subscription???
May 18, 2017 | Televison & Video
When on the digaital converter says no signal
Depending on type of antenna you have on the box the signal maybe too weak. But first try to lock channel 03 into your set. go to menu and add 03 where it has add/delete channels. If this still does not work select channel 04 and set your converter box switch to channel 4. This should do it.
Jan 18, 2009 | Sony RMT-V202 Remote Control
Remote start and door locks will only work from 10 feet or less
i had the same problem... go through the menu until you see reprogram remote. hit the check mark button and hold the lock and unlock button until the horn honks. key has to be on car not running though. You will eventually have to do it again but for some reason it will work for a while.
Dec 04, 2008 | 2006 Chevrolet Impala
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Philips Magnavox 20MT133S 20" TV Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
