Question about Philco (R) Bakelux 10245 CD Shelf System
The switch to turn the unit on doesn't work properly...
The switch is a three way, the radio plays cd's albums and regular radio however when trying to switch it on it doesn't work properly. We need a new switch but don't know where to find it. We checked radio shack with no luck!
    Problem Solver:
  • 5 Answers
Only plug in speakers that came with the system,and unplug and replug it in the wall.
Posted on May 28, 2009
I have problem with CD player.
The drive tries to read the CD but fails, then "resets" to try again. It is likely the complete unit will have to be replaced even though the other functions work.
May 04, 2014 | Panasonic Car Audio & Video
2008 Kia Grand Carnival, cd plays but no sound. Audio works fine for radio
Try cleaning the CD player with a cleaning disc, that is the best way to troubleshoot this at a less costly price tag.
Nov 23, 2013 | Car Audio & Video
Beeping noise when playing radio/cd?
Sounds like the unit will have to be reprogrammed with the cars VIN number. Your Peugeot dealer can do this for you.
Jul 23, 2013 | Car Audio & Video
A disk is stuck in my Harmon Kardon player. The door will open and close and I can see the disk but cant' get it out.
turn on the unit and then tried to press the play button while the cd tray is in place. if doesn't work, unplug the dvd player then open the cover to access the internal part. look for a broken limit switch for cd tray mechanical assembly or check weather the cd not in proper place in the tray that is why an error occur.
Sep 02, 2012 | Televison & Video
My ignition barrel broke for my vauxhall corsa,been fixed but my sony gt200 cd/radio will not come on . will not play.usually when you clip the front face unit into place the system lights up.at the moment...
your cd switch wire is not recieving any power. when you turn on your key it turns on the switch wire. the wire/contact on the ignition barrel may not have been connected properly. check the wiring and the barrel again
if this doesn't work connect the yellow and red wire at the back of the radio.it will work without the keys now
Sep 23, 2009 | Sony XPLOD CDX-GT200 CD Player
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
Radio plays and has sound CD player play with no sound
Blue and white wire is power antenna trigger.
Please use the solid blue wire for amplifier turn-on.
When you switch to another source other than AM/FM - that signal drops out (and the antenna lowers)
The MP228 does not have a built in crossover or dedicated mono subwoofer out... so you will need a seperate one, either standalone or built into your amplifier to cancel out frequencies above 80Hz.
There are also generic versions called "inline coil"
you wire in the positive line of each subwoofer that will filter out unwanted high frequencies.
f75a0e8.jpg (similar to this pic - but without the board... just the coil (top of board))
Harrison Labs make an F-Mod (available in divverent cutoff frequencies) that is installed in the RCA line.
You can try crutchfield.com for both types - and others.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 30, 2009 | Kenwood KDC-MP228 CD Player
My Dodge RAM Car CD will play OK, but won't eject.
If this a CD with a paper label, sometimes they will peel up on the edge and not allow the CD to eject or in same cases the CD is slightly warped.
One thing you might try is this..... Get a flash light and try and look into the CD slot when the radio is trying to eject. There is a black felt type material that you can lift up slightly and if you can see the disc edge trying to come out it may look like it is very slightly too high and getting caught. You can take a business card and try and slide it above the CD edge from the side and this will get the edge of the CD to come down and eject. This has worked many times for me anyway.
Mar 23, 2009 | 2005 Dodge Ram 1500
Subwoofer does not turn on when playin usb or cd or aux
I have the same problem..Have you guys sorted it yet?
Mar 12, 2009 | Car Audio & Video
Amp turns off
your radio has 2 blue wires. one of them provides a 12 volt turn on for a power antenna (when a cd is inserted that 12 volt turn on turns off, because when a cd is playing, the antenna doesn't need to be raised up). The other blue wire has a 12 volt turn whenever the radio or the cd is turned on--this is the blue wire that you need to connect to your amp remote line. ( pull out the radio and switch the blue wires)
respectfully,
Merle
Sep 12, 2008 | Kenwood KDC-MP4028 CD Player
Philco (R) Bakelux 10245 CD Shelf System Logo
59 people viewed this question
Top Philco Audio Players & Recorders Experts
OSU_Matthew
Level 1 Expert
 Grubhead
Grubhead
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
