Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w20 will come on for about 5 minutes them cut off
Green light comes on 3 time I have a rca d52w20 tv and it will come on for about five minutes then cutt off everytime. What is the problem?
  • 1030 Answers
SOURCE: RCA Projection TV won't turn on
Ok you got you a Rca ITC222 I See ALOT of these things. To start the troubleshooting.. UNPLUG the set for a min of 30 min the plug back up. ( I have never seen this work) If the set stil fails to come on then you have a processor lockup. The first thing you can conclude if the light flashes is it is NOT a FUSE. THe sets processor has determined that a safety condition has occured and shuts it down to prevent further damage and fire. THe top cause of this include Horizontal output trasistor, flyback transformer and high voltage splitter. but There is about 25 different failures that can drive it into shut down. technicains have interface equipment that can read errors codes much like a car.
typical repairs on this set run 150 to 350... if you have to replace tubes...250 per tube +labor which runs 250 ... these set new cost 800 so unless under warrenty.. you got to determine if it is worth it.
Posted on May 12, 2008
SOURCE: RCA won't come in
This was happening to us also~We found a solution with help from this site. We replace the CP150 capacitor which was bad. We replaced it with a 25v (it is normaly only a 16v 2200 uf). It helped but was not the whole problem. We also had a cold soder joint on a capacitor in the main power supply (the board with the two large capacitors and two transformers, they are tucked far back). This is the borad where the ac cord is connected. Hope this helps.
GOOD LUCK!!!
Posted on Feb 18, 2009
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
  • 1030 Answers
SOURCE: on front panel green light comes on 3 times but it
The rca itc222 is the technican best freind. WHy? because we make so much money on them because the break so often. LOL I work on 3 a day. The first thing from your description i can tell you is that it is not the main fuse. The processor of this set sees a problem and shuts the set down. Now the first thing you can do is to uplug the set for 30 min and try to restart the set. this has never work for me but it eleminates processor lockup possibilitys. Now as a tech then next thing i can tell you is that we have a special computer interface that reads error codes much like a automobile. There is about 25 different conditions or errors that can cause a shutdown. The most likely possiblities are high voltage tranformers called the flyback or the horizontal output transistors. If you a tech these are do it yourself stuff but in general this is not a tv for a non tech. tipical repairs run from 150 to 400 for this set
Posted on Mar 19, 2009
Slinteriors
  • 8617 Answers
SOURCE: RCA 52inch HDTV (2004 model) green power light flashes 3 times
Replace the flyback 259296 and the cp150 You can get the aprts with detailed instruction on how to do the repair at the following link.
http://servicemanuals.vstore.ca/
Posted on Jun 24, 2009
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w14 hit power green light blinks three times wont come on
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Tv wont come on
There is 3 capacitors on Deflection board cp150 2200uf 16v look to see if it is puffed up on top if so it is bad so replace other 2 caps cp114 and cp120 220uf 35v they are green with gold writing on them.
Dec 26, 2008 | RCA HD52W66 Projection Television
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
134 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
