Question about Ovens
My Maytag CRE9500ACE will not heat up past 250 degrees no matter what temp you set it to. We've replaced the sensor, checked to make sure both the broil and bake elements are working and still it won't heat up. We even tried to see if adjusting the thermostat via the display (which only changes it 35 degrees) would make a difference and it didn't. It looks like this is a common problem after looking though the many similar complaints on this website...whats the problem??
  • 6,784 Answers
HI, this is a logic chip failure that is housed on the control board. this is a well known issue concerning this model. The control board logic chip registers Resistance, via the Oven temp sensor assembly. This damaged chip is unable to process the resistance signal, in return, not allowing true oven temp to be produced. This actual Part has been discontinued. I have checked many sources for the part you will need and was told that it was no longer available.
Unfortunately, Maytag has pulled this Control Board off the market, due to its defect in the logic chip set. I will post the part number below just in case you would like to do your own search. the is the part that has failed and, if possible, you Willl need to replace it.
Maytag Part Number: 7601P200-60
Posted on May 28, 2009
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
My oven wont heat up to the temperature i set it at. it's at least 50 degrees lower than what it should be, and the temp fluctuates anywhere from 20 to 50 degrees while it's on, even without opening the...
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | GE Ovens
Why won't my Maytag electric oven heat past 210 degrees?
Hello could be oven thermostat,when you are sure of the part you need check out www.appliancepartssolutions.com cheep parts!
good luck
Apr 08, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Oven will not heat past 300 degrees
300 far. or cels if its celcius its to high they should run at about 260 or the high temp sensor will shut it down how fast is your belt running it should be 6.30 to 7.00
Jan 28, 2009 | Lincoln Conveyor Oven - 1133-000-A
Maytag MER5775QAS
Could be a couple things. If your machine is actually failing either a control board or an oven sensor.
Also measuring the temperature can only be done by a tech unless you have a special tool. Oven thermometers are inaccurate. Plus most ranges should vary temp between 50-75 degrees unless has a feature or the more recent ones keep it between 15-25 degrees.
Try the biscuit test, buy some biscuit, brand not important, i just say pillsbury. Cook exactly as recommended on package. If results are a little overcooked or a bit undercook try a feature called Adjusting the oven temperature or Calibrating the oven. This can be done by following the instructions in your book.
Maytag.com click support click manuals put in model MER5775QA (notice i took off your models S) open the Use guide, page 14
May 01, 2008 | Ovens
Ovens Logo
74 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
