Question about Cam Spray C1000E 1000 Psi Cold Water Electric Command Cart Pressure Washer With Mechanical Thermal Relief
Dies at intersection
2002 chrysler will die at intersection, right after we let off the gas and let it coast. Will do this randomly, three times now in the last month. just bought it about 2 months ago. has 94,000 with a 3.8 engine. Please Help, this is going to drive my wife to drinking and she doesn't drink
Car dies without warning
The symptoms you describe are similar to what I experienced on a 1994 Fiat 900cc. Sometimes it would just die and immediately restart, just to die again. Other times it would surge, almost like a misfire. There were no dashboard lights or error codes.
I disconnected the electrical wire on the MAF (Mass Airflow Sensor) and the car ran pretty ok... so I then replaced the MAF.
Try cleaning your mass airflow sensor to see if that makes any difference. You'll probably find a video on Youtube.
The link below is a generic google search:
chrysler 300 maf Google Search
Mar 25, 2017 | 1999 Chrysler 300M
Car keeps dying
Bring up low idle,is set screw on top throtle body.
Nov 21, 2013 | 1992 Chrysler Lebaron
Car sometimes dies in intersection
clean the throttle body most common cause of idle/decel die off. its cheap and real cheap and easy to do yourself
Apr 13, 2010 | 2001 Chrysler PT Cruiser
Car Won't run right and now not start
Check the gas it could be contaminated, Not to sould like a Wise guy but are you sude it 's not deisel fuel you put in.
Aug 03, 2009 | 1995 Oldsmobile Cutlass Supreme
Dies at interesection
Check the idle air control valve.
May 28, 2009 | 1998 Chrysler Sebring
ALL SENSORS HAVE BEEN CHANGED. FUEL FILTER CHANGED, FUEL PRESSURE IS AT SPECS AT IDLE BUT DIES IN GEAR. WILL RESTART BUT ALWAYS DIES. NO CODES IN SYSTEM WHEN IT DIES. NO HISTORY CODES. STILL HAVE...
Replace the distributor. This is the cause of many problems with the engine running on those cars. It contains the cam sensor, the coil and has been a thorn in many a side.
1996 chrysler sebring 2.5l v6 dies randomly
it sounds like it the crank pos. sensor
Apr 04, 2009 | 1996 Chrysler Sebring
1999 chrysler 300m stalls when coming to stop and low power
Change the Cam Position Sensor.. It done the same thing on mine. The sensor runs about
40. to 60.00 at most parts stores Your gonna have to take off the upper intake or plenum to
get access to it. Top of the engine right side, you'll see it
Nov 28, 2008 | 2004 Chrysler 300M
Cam Spray C1000E 1000 Psi Cold Water Electric Command Cart Pressure Washer With Mechanical Thermal Relief Logo
29 people viewed this question
Top Cam Spray Garden Experts
John Trevino
russlakeside
Level 1 Expert
Are you a Cam Spray Garden Expert? Answer questions, earn points and help others
