Question about Motorola Mobility RAZR V3
Screen doesn't work (no light )
Dark screen,no lights up. can use phone but u can't see who/what u wanna do. Only after multiple attempts of on/off/on the phone I have had similar problems in the past. Now the screen doesn't work at all.
  • 3 Answers
There is no solution for this issue. It is a Motorola issue. I have seen this with A lot of Motorola phones. No particular brand of Motorola. If it is under Warranty with your carrier take it in and do the Warranty exchange. If you do not have Warranty do the insurance if you carry it. Other wise I would call Motorola or go to their website. https://www.motorola.com/feedback.jsp
Posted on May 28, 2009
My htc has a dark screen and still works and by dark i mean you can barley see any thing but sometimes the screen goes back to normal light
Is your phone a smart phone?? Does it have something called ambient light sensor (light sensor).??? Check your phone manual. If that is the case then you can turn it off. Ambient light sensor is a function that senses the light outside and automatically adjust the brightness of the screen. But sometimes it goofes up. So you can go to settings> display settings> brightness> if it is auto then turn it to manual as per your convenience. Again depending on your phone model the settings may vary. I hope this helps.
Jan 17, 2014 | HTC explorer
Led tv dark screen, hard to see
tried with adjustment at the set up doesn't work?. if not check weather some of the LED back light are busted.
Oct 10, 2012 | Coby LEDTV1926 19 in. TV
I have a toshiba qosmio f25-av205, when you start it up the screen showes for about 15 seconds then goes dark, can see the screen on external monitor. Can also see it very faint on screen at same time. ...
In my experience, if a back light goes out, it doesn't work at all. Since yours works for a short time before going dark, I'd say that it's your inverter that's faulty.
May 08, 2011 | Computers & Internet
My screen went black in the middle of a call and has not turned on since then. I have plug it in and plug it into a computer nothing.
It appears your light sensor may be dirty or faulty, also, make sure you take off any case you have on your phone. The iPhone is designed so that when you put the phone to your ear, the screen goes black to conserve power and to prevent you from hitting buttons on the screen accidentally. If cleaning your screen doesn't work, you might want to have the unit checked out at your local apple store: www.apple.com/retail/locator/
A few other solutions may be to attempt to trigger the sensor again by moving a finger over the light sensor, or by shaking the phone, sometimes this has solved the problem.
Apr 21, 2011 | Apple iPhone 3GS Black (16 GB)
Hard drive lights solid,monitor goes dark/w amber power light. multiple hard drives have been tested with the same results.
NEVER BUY IBM!!!! THERE HARD DRIVES AND EXTERNAL HARD DRIVES NEVER WORK!!! SAME WITH HITACHI!!! if u wanna good external hard drives check out these links: store.westerndigital.com and http://www.seagate.com/www/en-us/products/external/ hope helps :)))
Dec 22, 2009 | IBM eserver xSeries 205 8480
Screen doesn't work. only after sereval attempts
This is a known problem for Razr V3. I had a phone like it with the same problem four years ago... I bought another brand and put the V3 away..three years later the phone works perfectly but I have not used it since three years..only turned it on to see if the screen will come on. Get the phone repaired or buy a new one. this is common on a RAZR
May 28, 2009 | Motorola Mobility RAZR V3
Can't see a thing on screen
hi sir
please remove the battery and memory card.. and after inserting the battery first for saffer side go to tools>settings>phone> restore factory setting . after restart insert memory card it work,s sir..
if doesn.t work mite memory card may be corrupted..
Sep 01, 2008 | Nokia N95 Cellular Phone
Nokia 6126 Screen problem
i have to say, the same thing happened to both of my nokia 6126's.
Jun 04, 2008 | Nokia 6126 Cellular Phone
Dark screen
go to your dispaly setings and check on the contrast and ilumination, if they are low, increase them and the screen will be bright
May 16, 2008 | Nokia 6133 Cellular Phone
My screen is to dark
I am assuming this is an lcd. Usally when a screen goes dark the back lights are not lighting. This can be caused by
  1. Back light failure (not Likely)
  2. Inverter failing. (most common reason)
The inverter board supplies the voltage to the back lights, it also supplies the video signal to the LCD tab welds.
If the monitor is a CRT, first, attempt to degauss it. if that fails then the cost of repair would exceed the replacement cost.
Mar 22, 2008 | Computers & Internet
Motorola Mobility RAZR V3 Logo
74 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
