Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 46in led tv power.
Yesterday, for reasons unknown, this tv simply shut off. No timer set or anything like that.
  • 822 Answers
Your power supply is damaged due to long time using without unplugged after use. its overheat cause. don't leave at stanby mode.
Posted on May 28, 2009
How do I fix my sharp TV
This is the board that has the bad part. http://www.shopjimmy.com/sharp-runtka932wjqz-power-supply-led-board.htm
Compare yours with the picture to see if there is anything visually wrong.
May 06, 2016 | Sharp AQUOS LC-60C6400U 60" 1080p LED-LCD...
My Sharp LE820 Aquos LED TV recently auto turn itself off, when I turn it back on, a few good 10 minutes or so later it automatic turn itself off again.
Please check that the sleep timer did not somehow get set. If it's not the sleep timer, check if the panel stays ON longer after it's been off for awhile to cool down. Possibly a heat problem with the power supply or main board.
Jan 15, 2015 | Sharp AQUOS 52in. LE820 LED LCD HDTV
Sharp aquos lc-46le810un won't power on, psu diode zener and fuse blows..cause?
Unhook the PSU from everything that you can and turn it on, see if it blows anything out. If it does not then you are looking at a non PSU problem. If it does then it is psu. You need to get the schematics for this set if you can.
Aug 09, 2014 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Half a screen on my sharp aqous
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 28, 2012 | Sharp 60" Aquos LED Smart TV - LC60LE640U
Sharp Blue Ray and Sharp Aquos TV were working just fine, now blue ray not recognized by tv; screen stays dark but the blue ray appears to be operating. Have tested the blue ray independently and worked...
A refurbished set? If blue ray is not built into set the issue is with the set--maybe the reason set was refurbished.....If have not tried it unplug set for a while and reconnect with set turned off.
May 01, 2012 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Sharp Aquos 46in Screen needs replaced. The front glass is not broke, it's the screen behind it. Is it replaceable and what would approximate cost be?
The display screen is the heart of the TV. If you're set is still under mfg. warranty you should contact them and they should be able to help you out. Otherwise with today's prices, the way they are, you would be ahead to purchase a new set.
Oct 22, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I have a brand new Aquos 52" LED TV and I accidentally locked remote operation and THEN found out the front touch screen panel was broken. Any way to manually reset the TV or remote to gain access to...
While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
Apr 04, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
373 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
