Question about Kyocera Mita FS 1010 Laser Printer
Kyocera FS-1010 I need to remove the front MFP tray to replace it as the original got broken. How do I remove the front cover to get the MFP unit out and then put the new one in? I have taken as many of the screws out that I can reach with a standard screwdriver but noticed there are some under the door/flap but I can't get to them until I get the front off! Thanks Sue
  • 417 Answers
You have properly removed the correct screws it's more likely that you haven't moved the clips that hold them down. You will need to take the top off first if the screws are causing the problem I suggest to get a bendy screw driver it has a flexible shaft and can be used at a angle of up to 90 degrees.
Hope this helps
Cheers J
Posted on Jan 02, 2008
Hi, I have an error code C7990 on a Kyocera FS-1028 MFP. Can someone help me on translation and fix of this error?
empty drum unit its full of waste toner each side of drum unit has plastic covers that pop off empty out the unit thoroughly and vacuum inside
Mar 11, 2017 | Kyocera FS-1028MFP Mono Multifunction...
Repair kyocera fs-1028 mfp machine failure call service c7990
developer unit fitted correctly or failure of developer unit .
May 21, 2014 | Kyocera Mita Kyocera FS-1028 MFP Laser...
How to reset a process unit
Make sure that the front and top covers close smoothly and fully. If the blue toner release arm is not fully to the rear the top cover will barely close. To reset the process unit you should remove it and then re-install it making sure it makes a good 'click' when you insert it.
Apr 15, 2014 | Kyocera Mita Kyocera FS-1028 MFP Laser...
How to open the fuser
You will need to open the cover on the rear of the machine to gain access to the fuser unit.
Jan 17, 2014 | Copystar Kyocera FS-C2126 MFP Printer
How do I empty the Kyocera FS 1010 waste toner reservoir? Stig
remove the proces unit (PU) end of the pu unit left side u have to remove a scrowe which is come inside a hole then rmove the cap and clean the waist toner....................
Oct 07, 2009 | Kyocera Mita FS 1010 Laser Printer
Kyocera FS 1010 printer. Not printing even with new cartridge
may be moisture.just switch the dehumidifier on for some tine.
Jan 18, 2009 | Kyocera Mita FS-1020D Laser Printer
Kyocera FS 1010 is printing blank pages
You may need an imaging unit. VERY expensive.
Sep 12, 2008 | Kyocera FS-4000DN Laser Printer
Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | Kyocera Mita FS 1010 Laser Printer
Kyocera Mita FS 1010 Laser Printer Logo
167 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
