Question about Nextar X3 GPS Receiver
Lost gps an cant remember the brand
Ok my gps was stollen out of my car an all they left was the charger is there a way i can type in the model numbers that are on it to find out what the type of gps i had.
    Master:
  • 409 Answers
You could try typing the numbers into google.  The chances are that the Power supply is used with several GPS's from one supplier.
Posted on May 28, 2009
  • 864 Answers
You could do a Google search of the model numbers and see what comes  up.  You will probably get some hits on Amazon or eBay that could identify the manufacturer's name or the type of GPS it goes with.
Ok for the thnth time here goes. the power connector is broken so that the battery cannot be charged. All I would like is to hane it fixed or replaced. I have the necessary sales slip. but at this...
For returns contact vendor customer service number, this is technical support.
Tell me vendor website address to find out contact.
Jul 28, 2008 | GPS
I lost my charger i cant find another one
If you are able to provide me with the make (example tomtom, garmin) and model (xl-3200, nuvi 100) then I will gladly help you find a suitable charger for you.
Mar 07, 2011 | GPS
I have a gps nextar with mp3 player and lost it .I have different cell phone chargers that has the same end as my gps charger Is it ok to use phone charger or do i need another gps charger.?
I advice you get another GPS, though, the phone charger might charge your GPS but it might just be epileptic charging because the rating on the GPS charger and your phone charger might not be the same, this way, you are partially rendering the life span and efficiency of the battery of your GPS down, and might lead to the damage og the battery.
I strongly advice you get another charger for the Gps.
Take care.
Jun 08, 2010 | GPS
Garmin charger has red light on and wont charge
mine too. Its brand new. Worked OK in my car for a couple of small trips, and unfortunately I didn't notice the lights status on the charger. Then lost satellite reception (not being charged at the time). Now red light on car charger and kept turning off/won't turn on. I have an old mains charger from garmin 660 which has a malfunctioning antenna and this 1490 was meant to replace ! Its charging now anddoes turn on, but no answer yet I'm afraid. I intend to register it with garmin and log a call with them. Also looking at the manual, it says there is a fuse in the head of the charger which should be checked. I haven't done this yet, but not sure if red light would be on if fuse had blown ?
Mar 13, 2010 | Garmin nuvi 255W GPS Receiver
Have lost manual. I need car charger for Mio P550 but Mio no longer making. Have purchased Scala AC Travel Charger Part No; SEL15305 (Input voltage 100-240VAC, 50/60Hz) and end is right but not sure if it...
The important thing is the ampage. If you have your old car charger check the ampage output. A higher amp rating charger will be ok as the p550 will only draw the current it needs. The voltage you listed sounds like a house charger not a portable car charger. cars run at 12v and the output should be something like 5v dc - 1amp (normally anyway).
Feb 18, 2010 | Mitac Mio P550 GPS Receiver
GPS charger of my car is not working.
first check and make sure the socket in the car is getting power, like trying your phone charger or something similar. if its not, locate the fuse in the car and see if its ok. if its ok check the fuse for the charger, most are in the tip that gets plugged in to the car. most can be removed by screwing the tip off. if the fuse is ok, then there is probably a problem with the gps.
Sep 02, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Lost gps and then found 6 months later and cant remember password
To reset your ONE XL, use a straightened paper clip, or something similar, to push the reset button. The reset button is next to the memory card slot, on the bottom of your ONE XL. Then turn your ONE XL on it will be back to it's factory settings.
May 11, 2009 | Tomtom ONE XL GPS
Garmin charger problems
19A259741 is the serial number. The model number should be to the left of that on the decal label. It's sounds like you have a Nuvi 2xx series.
The mini-USB jack is loose. Either is has come loose from the board or the connections within the jack are loose from everyday wear and tear (use).
If the jack is loose from the board and it needs to be resoldered or replaced if the jack is worn out.
- Jim
SHARCNET-USA
Dec 05, 2008 | Garmin nuvi 200W GPS Receiver
Nextar X3 GPS Receiver Logo
57 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
